Digital Ice and traditional b/w negs
Dralowid
Michael
8:49 AM
United Kingdom
Some advice much apperciated,
Before I take the plunge into Epson ownership I remember something about Digital Ice not working with traditional silver based films ... is this right or am I dreaming? Is it a problem?
I will be scanning mostly 35mm b/w and a little colour, also old m/f negs from time to time. The objective it to print from scans up to A4 in size.
Yes, I will crop from time to time but most of it will be full frame.
Do I really need to go all the way to Epson 750 etc or do folks reason one can get by with Epson 500 or less? My printer is not top of the range.
Thanks in advance
Michael
A4 from a 35mm negative means 297mm/36mm=8.25 times enlargement, From my experience, Epson V750 works best up to 6x, 8x becomes marginal. Best would be to get a second hand dedicated film scanner right away.
To apply ICE to b+w scan as a positive - invert in photoshop. Epson V700/750 is superb with MF but not so good with 35mm. As others have said, ideally get a dedicated film scanner for 35mm.
Please note that ICE doesn't work with silver halide bw films, as the IR channel that is used to detect scratches & dust cannot discern silver grain from any unwanted artifacts.
The story is entirely different, however, for chromogenic bw films, as these negs do not contain any silver. So, if you scan any bw film coming out of C-41 dev process, ICE will indeed be useful. Examples of chromogenic films are Ilford XP2 and Kodak BW 400 CN.
Thanks for advice so far. I'm going with a flatbed because apart from 35mm I have a lot of 120 and 620 old negs to scan. Mostly silver halide based. Back to Digital Ice. I'm assuming one can turn off or disable this feature on Epson V500 etc?
Am I right?
Thanks
Michael
