Thanks for the file tip, Mike.
As for the rinse time, I got that from some workflow data on one of the boards; I also remember that was the standard wash time 30 years ago for tri-x in the photo lab at a newspaper where I worked ...
I prefer the Ilford washing method for several reasons:
#1: I keep some canisters with tap water in my darkroom, at room temperature. Developer, stop bath, fixer and rinse water have the same temperature. Especially in winter there is no risk for the films. The temperature of tap water is never constant.
#2: It is guaranteed that the films are really clean, and that means according to archival standards.
#3: It saves huge amounts of water.
#4: It is a no-brainer.
And here it is, the Ilford washing method for films:
- Water at 20-25° C is fine. (I keep a big canister with tap water in the darkroom)
- Fill the tank with water and empty it. Make sure that whenever you empty the tank it is really emptied and that only a minimum amount of the previous bath is left in the tank.
- Fill the tank with water and invert 5 times, then just wait 5 minutes.
- Empty the tank, fill it with water, and invert 10 times, then just wait 5 minutes.
- Empty the tank, fill it with water, and invert 20 times, then just wait 5 minutes.
- Empty the tank, you have a perfectly washed film now. Just dry it as ususal.
