Roger Hicks
Yes, if you want to take advantage of the increased neg size and want to hand hold a 4x5, without a tripod you are compromising your quality (not to mention wasting money) or taking your chances that you are holding steady, you may (can) be able to hold steady enough a stop or more, just the same as one can when using 50mm on 135 film (many people shoot at lower speeds) but the 'rule' still applies!...if i only want equivalent quality to 35mm (in modern times) then i use 35mm, in years gone by they(the press) didnt have the choice due to other limitations (film speed, quality etc), not to mention they used flash, often
there is a difference between someone that has "tried it" out of curiosity and succeeding on occasion with making 'acceptable' prints comparable to 35mm enlarged to the same size and someone that uses it often and prefers to get their moneys worth out of the more expensive film and time and trouble one is put to when using LF. i suggest anyone walking around shooting 4x5 at 1/10 and 1/5, handheld, as you mentioned has a large percentage of worthless exposures!
Tell that to the pressmen of yore.
Also, what we're talking about here is prints of similar sharpness from different sized negatives, in which case, I defy you to find a flaw in my argument.
When it comes to huge enlargements, of course higher shutter speeds (or a tripod) give more quality, up to the point where blur due to camera shake is swamped by other factors. But the simple truth is that if you're shooting 35mm and 6x9cm, and making (let's say) an 8x12 inch/20x30cm enlargement, you can use slower shutter speeds than '1/focal length' with the bigger neg; that, in fact, 1/60 with 105mm (on 6x9) or 45mm (on 35mm) will give roughly equivalent sharpness, other things being equal (which they never are).
In other words, '1/focal length' is only a rule of thumb; it's not especially reliable; and it points towards shorter-than-necessary speeds with wide-angles and longer-than-desirable speeds with longer lenses. To which I'd add, and applies (insofar as it applies at all) to full-frame 35mm only. Or would you prefer to argue that 1/30 with a 30mm lens on half frame can be enlarged to the same size as a picture taken at 1/30 with a 50mm lens with exactly the same loss of sharpness, given the same degree of camera shake in both cases?
EDIT: I'm not saying that 1/10 and 1/5 are OPTIMUM speeds, merely that they often got publishable (i.e. not 'worthless') pics at these speeds. I am however saying that you don't need 1/125 with a 127mm lens -- and I cheerfully agree that a tripod is a better idea, but the OP was talking about HAND-HOLDABLE speeds.
