Do you shoot with scratches, cleaning marks or haze?
  • Scratches
    Votes: 56 18.9%
  • Cleaning marks
    Votes: 110 37.0%
  • Haze
    Votes: 28 9.4%
  • Other problems
    Votes: 24 8.1%
  • None! Mine's are Mint.
    Votes: 79 26.6%
  • Total voters
    297
About all my lenese have cleaning marks. A few with scratches. One with haze. The one with haze is a spiratone 400/8 slr lens. The haze is in the rear element & I've uncrewed the lens & tryed cleaning both sides of the glass to no avail. I'm begining to think the rear element is 2 pieces of glass & the haze is sandwitched between the two pieces of glass. Don't know how to clean it.
Or the adhesive is yellowing or separating... Oh, Maybe that is what the haze is :eek:
Many of my lenses have dust, scratches, cleaning ,marks, haze and even fungus. I shoot them anyway and try not to think about it.
I have a Vivitar 200 f3 which has a lot of fungus growing on several internal elements. It looks terrible, but I can't tell from the pictures it takes.
The scratchy Summar does great unless pointed at bright direct lights.
None of my lenses have any optical afflictions, I think. The exception being the M-Rokkor 28 I bought today that has some very light cleaning marks and some white fungus. But it cost me 175 dollars along with hood, caps and original box, so even if the fungus does cause flare, I'll be happy using it.
guess you bought it at schönherrsphoto? was very close to buying that lens a few weeks back, but tried it on my M8 but didn't really find it to my likening. the lens is small and light, but it is low contrast and not as sharp as my 28mm asph, but at 1750kr it's a bargain! hope you enjoy it!
My leica lenses are i good shape, but i do got som russians with a lot of defekts (fungus etc). I find that fungus isn't a dealbreaker really. as long as the lens is resonably sharp it's good enough to use
I just bought a "new" Summarit 50 f1.5. Looks nice, except for a white piece of debris, behind the front lens, and annoyingly right near the center.
Wouldn't be so annoying if it were off to the side.
Vick
Could you not just remove the front element and remove it?
or get a cla if you don't want to do it yourself?
I have a Summarit 50mm 1.5, scratched, hazy, engraved, it has it all.
I did get a few shots I really like out of it:
I was holding on to it as a lens for types where a soft, glowing look works for the subject and image. It works REALLY well for some subjects.
Unfortunately, I don't tend to shoot those subjects often enough to justify even one lens dedicated to it. I've been reluctant to buy anything with scratches or haze since that realization.
I have a Canon LTM 50mm/1.8 with some wild looking schneideritis (white dots) behind the front lens. No effect on image quality though.
My lenses are mostly clean, but where there are minor marks, or abrasions, I dont worry. one of my enlarging lenses has lots of fine cleaning marks but performs well. My best 50mm enlarging lens has a small chip right in the middle.
People worry more than they should and miss out on some good bargains because of largely cosmetic blemishes.
Yep, I have a rather substantial nick in this Summar, but I don't hesitate to mount it up and go shooting. My others I'm sure all have cleaning marks, scratches and other imperfections. Not that big of a deal to me.
Hi, i always take great care about lenses, in the past shot with not so good ones and early decided to go for mint ones even if i have to pay a lot more for them.
The fact is haze, scratches and cleaning marks waste many pictures.
If you add lens designs that suffer from flare or are uncoated then you can´t really shoot many things.
For instance i purchased a Foca camera that can´t use beacuse the seller 3000 kms away didn´t tell me it had heavy cleaning marks, to him this was a minimum concern!
Bye!
I only buy lenses that have mint glass, clean them once and then fit a filter. I'm not at all bothered by barrel cosmetics but the glass has to be mint. This is so that I have less trouble selling them on after I have tried them.
Cleaning marks wouldn't happen if people stopped over cleaning.
I had a zuiko 50 1.8 that was infested with spider web fungus and it was still as sharp as a mint copy I had. I think the main influence on image quality is haze. Fine scratches don't seem to matter. It's only when the surface shape is physically changed by polishing or chipping that I've noticed a difference.
Spots in lenses are noticeable when stopped down. I did some experiments with a marker pen on a filter a few years ago to find out.
This was shot with a 60's collapsible Elmar 50mm 2.8
Shot at 2.8
The rear of the front element had suffered from etching caused by oil vapour from the aperture blades and had been polished using toothpaste.
I really liked the results.
Well, I suspect, that after having cleaned some fungus off the front element of his precious Summicron-M 50 with great success, the owner of this lens will be much less picky about imperfections in his lenses in the future :D
For those of you who don't speak/read German, you're invited to have your guesses at what "old and proven household remedy for lens fungus removal" had such a decisive effect in removing the fungus...
:bang:
