raid
Dad Photographer
In particular, which type of cine lenses work on an Olympus EPL-2?
Is a D mount lens OK?
Here is a link to SLR magic. The price is a bit high I think.
http://cgi.ebay.com/SLR-Magic-35mm-...mera_Lenses&hash=item3a5d477251#ht_3235wt_922
Raid,
http://www.dpreview.com/news/1009/10090810zeisscine.asp
re: Zeiss making cine lenses for 4/3 cameras.
Hope this helps.
Best regards,
Bob
C-mount lenses on m4/3 stikes me as a weird niche, no good/bad value judgment intended. There are different, sometimes contrary reasons to use c-mount optics, with prices ranging from $20-$2,000+. There's also a wide range of image rendition depending on lens formula, focal length and speed.
Most c-mount lenses are made for smaller image formats, and the wider lenses, especially wide/fast lenses, have a look many love. Sharp center, soft (often vignetted) corners and swirly bokeh.
Longer and slower lenses usually have a more familiar rendition, more like full-frame optics, though few, if any, are going to be as sharp corner-corner as most legacy 35mm-frame optics.
Many of the wide/fast optics are relatively cheap, while a few of the anointed ones are very expensive. It's kind of fun to find a tiny 25/1.5 lens for $60, but you need to really like the look of the 25/0.95 Angenieux to spend $1,000+ for one.
I've played with a few c-mount lenses, and in general I don't find them very useful for my photos. I'm more into sharpness and contrast, less into vignetted corners and swirly bokeh. The wide/fast lenses I can afford are pretty soft and flarey wide-open, and if I had $1,000+ for the 25/.95 Ang. I'd rather spend it on the 25/.95 Cosina/V'lander, or 7-14 Panny. I don't find the longer focal lengths distinctive enough to be really distinctive, so why not just use a legacy 50/1.8, 85/1.8, etc?
But that's just me, I have seen some very nice work done with c-mount lenses. Images I like to look at, not images I'm motivated to make for myself.
For you, Raid, I'd first ask myself why I'm interested in c-mount lenses, what my budget is, and what focal length best matches my needs/wants. There are lots of flickr groups with c-mount output, shouldn't be too hard to see the different looks possible...
I use adapted CCTV lenses regularly, and have tried some of the old cine lenses.
There are, actually, some D-mount lenses that work. They're generally "telephotos", in the 35-40mm range. They have a much larger than normal image circle, and if you remove their mount and spend $1.50 on plumbing parts at the hardware store you can mount them in a C-mount to micro-4/3 adapter. It's a bit of a time investment, but can be worth it.
What you get from adapting cine lenses (the common-ish ones, not talking about the expensive stuff here) in that ~30-50mm range is a TINY "portrait" lens with a distinctive classic character that's a lot nicer (imo) to carry around and use than the only similarly-priced alternatives, which are normal lenses from legacy 35mm SLR systems.
Are there any suggested prices for such Zeiss lenses? No Zeiss lens is cheap.
Zeiss CP2s are generally around £2500 in the UK, pretty cheap for motion picture lenses, I believe leica summilux-C lenses are around $180,000 a set.
