What gear would you pack ?
srtiwari
Daktari
6:21 AM
Vero Beach, Florida
I'm part of a Medical Mission going to the Dominican Republic in May, for a week. The team of 20 consists of Surgeons, O.R. nurses, and various Medical specialists.
I plan to document the trip in images, and am pondering what my travel kit should consist of. The photographs will be taken outside, as well as in the clinics, operating rooms, and inside homes. I expect to take Color and B+W film, and will likely bring it back home to develop, here in the US.
My plan is to carry 2 bodies, 3 lenses, 24 rolls of film, and filters etc.
(I will also carry a Digital P&S, as backup)
Limiting oneself to the M system of RF bodies and lenses, what would you take ? The kit needs to fit into a backpack type case.
1. Which camera bodies , and why ?
2. Which lenses and why ?
3. How many color film rolls, how many B+W films and which ones ( not to total more than 24) ?
I look forward to suggestions, specially from those who have planned for similar trips...
For pictures inside clinics, operating rooms, and inside homes I would take a fast 1.2/ 1.4 35mm lens. I tend to like having a really wide angle lens (15mm?). It will allow images in really tight places and it gives a unique look. For a third lens I would choose a 50 or 75. I like the 75, but frame lines can be an issue depending on the body you have. The camera bodies to take are the ones you have in my opinion.
Couple of metered cameras
24/50/90 mm lenses
Some low iso (100) film some medium (400) and a couple of fast (1600+) is what I would take
Actually Id take my d3 and 24-70 and leave it at that.
Just a suggestion: I would put down all the stuff you are planning to take with you, and think: what can I leave home? Put that aside ans think again. Than weed out something else. And so forth, down to 1 camera an max. of 2 lenses- wide and 50mm.
It looks cool and exciting now to have this lenses and that camera, and so forth, but in real life if you want to get real pictures, you will not have time to fiddle around. Limit yourself in gear and concentrate on pictures.
(Sorry if it goes against the whole premise of gear forum, but it's either pictures or toying with multiple gear, choice is yours...)
Just my 2 cents, a 28mm & a fast 50mm. You will not use the 90 much at all. I took a trip in November for 5 days. Most all of my shots inside & out were shot with my 28. Very few with the 90mm, some with the 50mm. Less is better.
What type of photography do you plan on doing? If it's all documentary work than I agree with most of the others with two bodies with a fast 50 and a 28 but if you're planning on doing some portrait work than a 90 would have to go along as well unless the you're comfortable using the 50 for portrait work.
Twenty-four rolls of film is WAY too little film for a trip like this. That works out to three rolls a day. You could shoot three rolls in an hour depending on what is going on in the operating rooms, etc. I spent 24 hours documenting a Vet hospital a few years ago and burned through 18 rolls of film. After, when looking through the negs I wished I had shot even more.
If it were me, and I was taking an M system, and I was working with the gear I have to hand, I'd take my M3 and one Hexar RF along with my CV 28mm/f1.9, 35mm/f2 UC Hexanon, 50mm/f1.5 C-Sonnar and 75mm/f1.4 Summilux. I'd probably take the HX-18 flash for the Hexar RF, and I probably wouldn't use it (somehow I never do).
I have a bag where I can pack those with hoods etc. along with quite a few rolls of film, that makes a nice compact package and isn't a bother to walk around with. I'd probably take (empty) a camera pouch I use that holds a single camera and spare lens, which might come in handy if I didn't want all my gear with me at once.
For film, I'd take mostly Tri-X, along with a few rolls of Reala and a couple each of Portra 800, Superia 1600 (the press-pack stuff) and Delta 3200.
...Mike
I have taken 21, 28 and 50 with me. I missed longer lens at times. Now I'd take 21, 35 and either 75 or 85/90, or possibly 21, 50 and 135. At least one of these has to be a fast lens - either 35 or 50mm. And I would NEVER go on any trip without 21mm lens - gotta have it!
I appreciate so many ideas offered !
I am leaning towards-
My M7 for Color, and the M2 for B+W, and a hand held meter.
I can take my ZM 50/2, and the Summicron 35 (V3), for most of the work.
And then a CV 25/4 for closed spaces. I can add the 90 Rokkor without adding too much weight.
I'm going to try and take 20 rolls of each of Tri-x, and Pro 400H.
Hopefully a Polariser, a Yellow filter, and a small desktop tripod.
None of these lenses have similar "signatures", but oh, well...
I plan to try to have the film "hand-checked" at Airport security in both directions, but no idea how difficult this will be.
Any other ideas, thoughts, tips or tricks I could use ?
JSU, thanks for the advice. Actually, I do have the CV 21/4 with finder, but have less experience using it (I was actually thinking of selling it !). Perhaps I should use/try it more since I have a few weeks before the trip yet.
Just a thought about film- most people are recommending more. All of a sudden, my little "stash" of 300 or so rolls doesn't sound like something that will last "for years..."
Less is more...
On the 2nd day, or earlier, you'll be kicking yourself for hauling TWO bodies and FOUR lenses. Take ONE body (unless one is digital) and only two (one preferably) lenses..and make sure you only take your fastest lenses. And leave the 90mm at home regardless.
And double or triple your film amounts if you're going to be shooting non-stop as your only duty. Double if it's not your only duty. Just do it and trust 😉
And take two sets of batteries...for everything...just in case.
You did not say what lenses you possess. First, designate one camera for color and one for B&W. Lenses: A wide for the whole scene. A 35mm is probably going to be your standard. Use a fast 50mm for tighter shots. I seriously doubt that you will need anything longer than a 50mm if you are going to be in close quarters. The 75/90mms are for portraits and this situation does not appear to be portrait driven. A 135mm is for when you can not get close at all. I suspect that as part of a team you will very close to the action. Then the standard as part of the team will be the 35mm f2.0 w/400 or more film. As far as backup for 2 weeks a second M is more than enough as a backup. To save space if you are designating one camera B&W and one Color go with 12 of each and 36 exposure rolls to conserve space. That should give to you 864 shots, more than enough to document the mission. Good luck.
I'd also suggest that is too much stuff, unless your sole purpose on the trip is as photographer - in which case your clients will tell you what they expect, and it will probably be digital!
One metered body, plus your favourite 'normal' length (50 or 35) at f1,4 -ish, plus a wide (maybe 28 or 21, depending on the other lens) plus a small thyristor-flash with tiltable/bounceable head. Also spare batteries as required. Only black-and-white film, think of both how much light you expect and how contrasty it will be in order to decide what exactly. For colour use the little digital to simplify the film-body problem, so you'll need batteries and cards for that I guess.
A week isn't very long, and you also have arriving/leaving within that week ? You could be too busy for pictures! I'd further suggest putting all this hardware in a (small) bag and take it everywhere with you - hygiene rules permitting. How are you going to get an 'outside' camera in to an O.R. ?
Basic kit: 1 body + fast 'standard' (35/1.4 for me)
Second body for backup (even Leicas can go wrong) AND to work faster (2 bodies + 2 lenses is far quicker and more efficient than 1 body + 3 lenses):
On the second body mount one of the following lenses
Real wide-angle (15-18-21)
Slightly long lens(75 or 90), also good for close-ups (about 1/10 life size).
