LTM lens cleaning
Brian Legge
4:48 AM
Seattle, WA
I have a few lenses which could use some basic cleaning. I've done some research and come across a bunch of names but its challenging to know what information is still good, given how rapidly things all changes.
Lens in question:
- Canon 50mm 1.8, stiff aperture (to the point where i worry about tearing)
- Elmar 50mm 3.5, debris between the elements.
- Summaron 35mm 3.5, debris between the elements, stiff focus.
I'm comfortable working on some lenses - I've done a lot of work with FSU and Nikon SLR lenses - but these ones seem a bit more difficult to work with. None of these are premium lenses so its hard to stomach spending $120+ each (the best of first round of prices I found) on what seems like it ought to be relatively basic service.
At the same time, the glass is in good condition so they seem worth some work.
Any recommendations on people who can perform basic work at a decent price?
Presuming the Summaron is coated, it's a "must send out". Lenses with the Leica soft coatings are very difficult to clean without removing the all-important coating. Has to be done chemically. Moreover, small highly curved elements, could be hard to keep them properly centered.
Elements can be very snug in an Elmar 50/3.5. If it's coated, don't even think about D.I.Y.
The Canon 50/1.8 is indeed easy to work on. Plus, it's hard coated, hard to damage the coating. Be sure to make those scribe marks Ferider mentions, so that the lens will be the same focal length when you're done. (Otherwise recollimation becomes an issue.)
If the lens has had fungus at any point, the coatings may be terminally damaged. It takes an expert repairer to spot the difference between coating deterioration and normal evaporated-lubricant haze.
With damaged coatings the lens can still be sharp, but it will flare all too easily in contrasty lighting.
