Do you - or did you, make notes? Show us a sample...
LKeithR
Improving daily--I think.
11:40 AM
Langley, B.C.
I was digging through some old boxes of "junk" (my wife's definition, not mine) the other day and came across an old notebook I used to keep track of my photo settings, subjects and locations. It brought back a lot of memories and reminded me of a few things I had forgotten. To date I've been pretty good about remembering when and where most of my old film shots were taken but the notebook helped to clarify some things I wasn't sure of.
Sadly, I haven't always been this diligent when it comes to making notes and I only have records from certain specific "periods" of my life. Still, something is better than nothing. If you kept any notes yourself it would be interesting to see samples...
That's pretty impressive.
Before starting a roll, I always make it a point to keep notes, but ultimately laziness takes over the determination. :bang::bang::bang:
I am hoping some day I will be able to break this cycle, but I don't think I will be making such detailed notes, hell I don't even remember the last time I used a pen and paper. :bang::bang:
Oh man, this thread is depressing....
Keith, an interesting find, I'll bet. I used to use 4x6 file cards, one for each roll of film or related sequence of several rolls. It had subject data and technical data including developing and print-making. I numbered each roll and the number appeared on the file card, the negative sleeve, and on each print by frame number.
Back around year 2000 I changed my roll numbering system from sequential to date related yymmdd.
I usually make the notes after returning from a photo excursion; if I'm in truly unfamiliar places I may make some notes as I shoot.
After I got a computer in the mid-1980's, I transcribed all this info to a database, and I've kept it current on the computer ever since. My memory needs all the help it can get.😱
attachment.php
Can not post right now (not that impressive anyhow) but I do make notes when starting a new roll. Depends how quickly I get through I would note the location. But more detailed notes I only do for 4x5. I use the small (~ A6 size) black Moleskine notebooks as they are well done and do not fall apart if carried in a back for a longer time (and I love the way the paper feels)
When I started photography 35 years ago my father adviced me to take a notebook with me.
"You might note the settings for each picture" he said, "then you will progress quickly, comparing your notes and the results".
He was certainly right… I never took notes when I was photographing, and it's certainly the reason that 35 years later I'm always a bad photographer.
I try to make some notes when I have time, on random pieces of paper, in small notebooks, on the phone (in writing or as audio), etc. Once I get home, I put the notes on my computer and store them with the files/scans and in Aperture. Very seldom do I actually use the notes for anything, but having some extra information available never hurts.
I carry a Moleskine notebook to keep notes in, but I don't bother keeping exposure notes like that. I keep notes of what I photograph. Locations, subject matter, dates...stuff that's useful to know years from now when I am famous and my work is published. Exposure data isn't really useful or needed unless you're experimenting to test a new film or testing a camera you suspect is not working right.
I've tried doing that with film, but I'd forget a shot or miss something and mess all the following ones up.
With digital, the EXIF automatically records shot technicalities for you.
I do however have an 'ideas' moleskine that I write in, and record possible lighting setups etc. Not very well though...
I am hoping some day I will be able to break this cycle, but I don't think I will be making such detailed notes...
Not all of my notes are that detailed; and for some periods I have none at all. The ones I've shown were from a "learning and experimenting" period so for two or three years they were very detailed but more on the technical side--like EXIF info. At other times I was more interested in recording time and place and perhaps some thoughts about my subjects. There were, however, also many gaps where I have nothing whatsoever for records and now, looking back, I wish I had been more diligent. Time and discipline are required and sometimes I lack both--as I'm sure do many others.
All I can say to all you "youngsters" on here is that if it's at all possible for you to keep some notes--however skeletal they may be--you will most likely treasure them in your later years. I know I do...
It's fun to be able to search back to see when and how often I used certain gear, film, developer, etc... but I think the most useful in the long run is subject/date/location. Over the years, buildings go up and down, businesses change, streets/roads are widened or re-routed. The notes identify what might well be unrecognizable later on. Finally, it's all an aid to my own memory as to what I was doing at that time.
I take notes when I am out shooting work for the paper. They need names and location information when were going to publish photos. I don't usually take notes otherwise.
Wow are those detailed notes. Only on a long vacation type trip do I take a small pocket memo pad and write down where each roll was shot and if I change the ISO from the manufacturer's stated speed. Otherwise, on a 1 or 2 day photo outing, everything is jumbled together.
When I started taking photography seriously with my first SLR in 1996 I was quite strict with myself. I learnt on slide film after I quickly discovered labs could print out exposure errors. I used to have a small note book and note the aperture & shutter speed next to each frame plus any relevant info such as exp. Compensation for snow, beaches, dark subjects etc. It served me well and I quickly mastered exposure. Of course now I shoot RAW on my Nikon but I'm greatful of that discipline when shooting slides in the Leica. 99% of the time I can guess to within 1/2 stop of what it's meter says and adjust from there. It even proved useful when I 'argued' with the meter, which made me check the back of the M6 TTL, only to discover I'd not changed the ISO setting from 400 to 100. 😱
I write all my b&w info on the negative sleeve, iso, dev, ratio & time.
Steve.
Of course 🙂
Wow! Maps too, I'm impressed.
When I first got to taking photographs seriously, Using my father's 9x12 with its 127 adapter, I kept good notes. I did a lot of museum shooting under poor light conditions. I had too know what camera settings I had used that got good results. If I remember, I will look for my notebook tonight.
In the Army I often took notes in case a defense attourney decided to try and discredit me by asking for them (never happened), so I eventually quit doing so. After all, the only thing needed to authenticate a photo was that it depicted the scene as I had seen it.
Now I don't unless as others, I am experimenting for some reason. And I probably don't keep them long either although I know I should.
