Krosya
Konicaze
A couple more from the M-Hex 35/2 taken with Bessa R2:
m-hexanon 35 draws very similar to Leica 35/1.4 asph at the same f-stops.
I think the non UC Hexanon 35/2s might be like summicrons.
I own a 35 Summicron-M Asph and carefully compared it to a 35 Biogon, which I owned and sold. Wide open, the Summicron Asph outperforms the Biogon—the Summicron Asph showed a significantly better ability to render points of light as points of light (less chromatic aberration?) and delivered higher acutance.
Wide open or close to wide open is where the 35 Summicron Asph distinguishes itself from the 35 Biogon. If you shoot only at f/8, don't spend the extra money on the Summicron Asph.
I have the 35mm asph summilux, and I'd disagree. Not better, just different.
I recommend a little background reading.
