Ezzie
E. D. Russell Roberts
Thank you Ron. Much appreciated.
Egreaux
Some of my favorites!
Mcary
Zeiss 533/16 Tri-X @1600 XTOL 1-1 full strength time from Kodak Tri-X PDF
Mr_Flibble
In Tabulas Argenteas Refero
Zeiss Ikon Nettar with 11cm f/4.5 Anastigmat, Ilford XP2
In the Footsteps of the 82nd Airborne 2011
P C Headland
archeophoto
I love 1950's quality
roboflick
Franka Solida III radionar 2,9/80
Beautiful!
tjh
Absolutely wonderful pictures -
bigeye
Ansco Speedex 'Special'
(Tri-X @100ASA & EV16+1, XTOL 1:2 5'30")
dotur
od karnevala
Brian Legge
Iskra
FP4+ at 100
Rodinal 1:50, 15 minutes total, 30 seconds initial agitation, 10 seconds every two minutes
These are from the first roll after fixing a light leak with the camera - as much a test roll as anything.
http://www.flickr.com/photos/cannelbrae/5696828422
http://www.flickr.com/photos/cannelbrae/5696321587
http://www.flickr.com/photos/cannelbrae/5696302065
FP4+ at 100
P C Headland
Iskra
FP4+ at 100
These are from the first roll after fixing a light leak with the camera - as much a test roll as anything.![]()
Seems you may have fixed the leak - where was it?
Brian Legge
I followed the recommendation here:
http://www.rangefinderforum.com/forums/showthread.php?t=58597
One of the two leaks looked exactly like the issue people had in this thread. I put some gaffe tape down and covered the slits and the problem seems to have gone away.
I still have a thin leak near where the toothed sprocket hits the film - it leaves a straight line across all frames and spaces between them - but that one is easy to crop and and is lower priority in general.
fidget
Lemon magnet
A crop from a frame from my Ikonta 521 on FP4+ overexposed.
A strange flare like effect from each of the bright spots on the frame.
No other frames show this.
Dave
Dave
whitecat
Lone Range(find)er
$40.00 Zeiss Nettar........
whitecat
Lone Range(find)er
Another from the Nettar, most under rated folder IMHO.
Borghesia
OK Nettar time... here's mine from my Nettar, black and white photo, handcolored in PS :
tahmasib
Zeiss Ikonta 521 / novar
Avispartner
whitecat
Lone Range(find)er
Let's get some more Nettar pics here......
