TriX at 3200!!!
I've gotten pretty grainy and contrasty results doing this; I don't mind but may not be what you're going for.
I just did some tri-x at 3200 in Microphen 1+0. 25 mins @ 68 F. Agitated 2x every other minute (1,3,5 etc)
You may or may not like the results, I didn't think they were too bad for a first try (I used to send my push processing out).
Good luck, let us know your results..
Except the 1st photo (which looks kind of pastel like especially on his face, maybe the scanning?), the other 2 came out pretty well. That middle one (3 guys) is just awesome. I kind of like your agitation routine.
I do Tri-X in Rodinal, 1:50 at 16-18deg for 45 minutes. 20 initial agitations then 5 gentle agitations every 5 minutes. Works for me, less Contrasty etc.
And this is out past 6400, close to 8000 going of my lightmeter, this was around 80-90 minutes same process as above.
These are absolutely wonderful, I can't believe that 2nd one was shot at 8000!! Too bad I don't have rodinal.
I do Tri-X @ 1600 in Rodinal 1:100 for one hour stand development. One minute constant agitation then let it sit, untouched, for 59 minutes. Temp between 68 and 72 degrees F.
I did somewhat the same as you guessing at an exposure which I metered after the fact. Likewise it was closer the 3200, actually a 1/3 of a stop beyond, call it 4000.
I processed in Rodinal 1:100 but went 90 minutes instead of 60. I also agitated very gently for 10 seconds at the 30 and 60 minute marks.
Like this one too, I am kind of getting the feeling that rodinal might be the answer to "really" push this film "and" get good results.
Sometimes I agitate, sometimes I don't. Not exactly scientific and I don't recommend my way of processing.
Lol, I wish I was as carefree. Problem is, I have just started to develop on my own and want to keep it a little scientific if I can, until I develop my own unscientific methods. :)
reiner - amazing. can you give developing details?
Sure I can.
For 120 films, Tri-X 400 @ 3200 in T-max-Dev 1+4, 24 degrees, first minute continuous moving, then every minute 3 times, 14 minutes.
For 120 films, Tri-X 400 @ 6400 in T-max-Dev 1+4, 24 degrees, first minute continuous moving, then every 30 sec 2 times, 25 minutes.
For 35mm it should be the same, but I haven't tried it yet.
Give it a try
Excellent photos ChrisP, esp the guitar ones and the 4th one in the last set (lovely reflections).
I am about to develop my roll this evening, will post comments tonight and results tomorrow.
Thanks for all the help.
just for fun I developed a TRI-X in HC-110 dil G some years ago....
good results but I don't remember about time....
I need to check...
Negatives came out great, there are at least a 3rd of usable photos if not more..will post some scans tomorrow. :p
