That's going to be nice though...the eye level finders are a classic on that camera. Love the really pointed peak (which gets easily dented), reminds me of the OM1.
This is my beaten up F, you should have seen it when it arrived. A bit better now the repaint could have been better but it will probably be stripped again later in the year for another up-grade.
Seeing you photo reminded me that a few years ago I considered buying a CV 12 for use on my F or F2, and rather than paying for the finder mount,
I decided to make one myself starting with a beat-up F/F2 waist-level finder, and after removing the spring-loaded fold-up bits, add a base and coldshoe that would hold the finder.
I never finished because I bought an auto-focus 12~24 instead which has been dedicated to a low-end autofocus film body , but I thought I'd mention this to you because attaching the 21mm finder off to one side over the re-wind crank seems to me to be a very unsatisfactory place for it, and if you're handy, you could make a finder holder, so it will sit directly in line with the lens, as it should be.
Rbsinto,
The offset finder is only inaccurate to the width of the centres. 5cm to be exact, project that to a subject at infinity and it is almost not significant.
Rbsinto,
I understand, but besides being slightly less awkward to look through the finder when it is centered, with that mount there is no need to remove the finder to re-load the camera. It's not quite as bad on an F2 where there is a film door, but with an F you have a loose finder as well as the bottom/back to contend with, not to mention two rolls of film (one exposed and one unexposed). I'm always in favor of doing everything I can to make my life easier (short of growing more hands) when using gear with quaint but annoying quirks.
