Replace 35/1.4 with 28/1.9 ?
jazzwave
3:39 PM
Here the story:
Initially, I have Nokton 35/1.4 for my M8,then I bought Plannar 50/2.
Now, I'm feeling that 35mm not wide enough for me.
I plan to have only 2 lens : 50mm and wide lens for street and lanscape .
Is it wise to replace the magnificent Nokton 35/1.4 with lens below?
Ultron 28/1.9 or 28/2
Appreciate, if you can help to choose and "open" my mind.
~ronni~
I would prefer it. I am more interested in even wider though. The pictures I have seen are fantastic from the 28/1.9.
If you get the 28/1.9, make sure you get a proper Voigtländer Type 2 adapter that can be 6-bit coded, or your pictures will suffer cyan corners if you use a UV/IR filter. Also, don't get a cheap adapter since these are often too thick or too thin, which will mess up focusing. A proper Voigtländer (or Leica) M39->M adapter will ensure proper focusing with the lens.
You won't have to worry about an adapter with the 28/2, since it's M mount. Allegedly (I didn't use it), the 28/2 has higher contrast, but MAY suffer from slight focus shift. The difference in speed is negligible.
Here you can find some pictures taken with the 28/1.9 on an M8: http://www.efixmedia.de/photography/tag/ultron-281-9/
Sounds like you need/want at least a 28 or even something wider. I have both the 28 Ultron and the 35 Nokton. While I like the size, handling, and build of the 35 better, they are both nice lenses and I am very pleased to own and use them. Perhaps you should look at something wider, though, as long as lens speed is not an issue.
Lss,
You got my point, yes actually I need wider than 28 due to crop factor on M8.
But I don't have big buck to buy 21/2.8 or 24/2.8, the option probably;Skopar 21/4 or 25/4.
I need wide open because give shallow DoF and I love it.
~ron~
You got my point, yes actually I need wider than 28 due to crop factor on M8...
That makes it easy... a 28/21mm it is... Now, the next question is this: Do you need the extra 2 stops of speed of the 28/1.9 over the 21/4?
You answered that question, too 🙂. Go ahead and get it.
This thread got me thinking... I don't have an M8 or M9, (Just my R2) but I've been pretty happy with my 35 / 50mm combo and now I wonder if a 28 / 50mm combo would be more versatile. Especially considering I have the Fuji X100 which is only a 35mm (equiv.)
Hmmmm.....
Hmmmm.....
Finally I added CV 21/4 to my lens line (35 and 50).
On M8 ,21mm equivalent to 28mm..this nice focal lens. Not too hard to compose.
So my opinion, 28mm and R2 will be perfect combination ,
Yes I would do the same, but I'd probably go for the newer 28/2.
However, I kept both my m lenses at 35/2 and 50/1.4.
The reason is when my m is mounted with the 35/2, I will have the ep3 mounted with 45/1.8.
When the m is mounted with the 50/1.4, I will have thw ep3 mounted with the 12/2.
I hate the idea of changing lenses in the middle of a photo walk for example.
