deirdre
I have a 1952 5cm Summitar with light haze. Here's a picture SOOC taken with it under conditions that show its reduced contrast. Here's a picture I took with it, then adjusted the levels, and it's accurate, color and clarity wise.
Any shooting into brighter light will tend to make things worse for that lens, but it's fine in shadow or under select lighting conditions if you don't mind doing the post.
Eventually, it'll get gussied up, but for now it's the way it is.
