M8 rangefinder realignment help needed
defektive
Aussie
4:46 AM
Tasmania, Australia
My apologies if this has already been covered here, please point me in the right direction if it has.
I picked up my M8 today and the rangefinder has become misaligned vertically since I last used it (must have copped a knock on our way home from holidays last week). Can someone give me a detailed description of how to fix it and what tools I need please?
Regards,
Sam
Hi Sam,
This happened to me two weeks ago when i was first testing my camera, I have taken it off to the local camera story here in Sydney for repair.
I think they are ripping me off as it is costing $250 to get re-aligned. But otherwise, if you get in contact with Adeal, they may be able to help you...
Good luck!
Hi Sam,
Good luck!
It is a ten minute job- that is indeed a ripoff
I've always found Foto Riesel in Sydney to be very helpful but their prices seem to be on the high end.
There used to be a fellow in the Dymocks building who did Leica repairs. He was fantastic and reasonably priced but I understand he has retired..
The only options left for repairs/adjutments are either Perth or Melbourne. You may want to speak to Scott at Mainline Photo in Crows Nest and discuss your problem. He has been most helpful recently with arranging a lens CLA.
I hope someone provides a good answer. I am guessing that Leica purposely made it impossible to remove with leaving signs, as a indicator of "unauthorized entry".
There have been a couple historical precedents:
- the seal at the top of the lens mount for Leica M's
- the cover of the rewind knob on Nikon F2 cameras
- the name label for the Contarex Super Electronic camera
It is virtually impossible to open up those cameras without destroying the cosmetic part.
Vick
Twist the dot left and right with your thumb to loosen it a bit and then work it with two toothpicks until it slides off,adhesive intact.
Apply a minidrop -mini not to get it into the rest of the camera!- of Acetone to the securing compound on the adjusting fork to soften it.
Insert the tool, point the camera at a distant object with the lensat infinity and twist to adjust. Leave for a few minutes for the securing "glue" to harden again and reapply the dot.
Leica does not regard this adjusting operation as something that voids the guaranty, if done properly. It is undetectable anyway. Changing the dotfor another type is fine with them as well.
The last Leica M mount with a wax seal at the 12 o'clock lens mount screw was the M4-P. Starting with M6 there is neither a wax seal, nor even the need to remove that screw to get the top plate off. On my M4 before I sent it for overhaul, I removed the top plate and filed off the tab that goes behind the 12 o'clock mount screw (it really isn't needed, as the M6 and later bodies prove). Now I can get under the top plate any time I want (to adjust the 1/1000 shutter speed, or clean out the viewfinder) without disturbing the "92" wax seal DAG put there.
if the vertical alignement went off because of a shock, chances are that the horizontal is off too. Send it to a good repairman that can fix everything 🙂 correct price should be around 100USD
Bloody Hell! I just got the repair quote back and it's $300 locally so I rang a repairer in Melbourne and they said $200-250. I'm confident the rangefinder is accurate horizontally so I think I'll just buy the $60 tool off eBay and have a crack myself.
Before I start hucking in, has anyone heard of any horror stories regarding DIY rangefinder vertical realignment?
