Delta 3200 exposed @100
MineSix66
12:22 AM
I accidentally exposed Ilfold Delta 3200 @100 does anyone have any recommendations for developing? I have Ilfosol 3,Diafine, Pmk Pyro, HC110 and Rodinal. The pictures were taken outside, in partially cloudy mostly bright sun , with 120 film at f8 - f11 1/50 - 1/250 speed. Thanks🙁
That's an almost perfect exposure.
Film's ISO is close to 800: it's a flat contrast film in general (more than Kodak P3200) so you can push it up to 6400 and yet get results without a horrible wild contrast...
If your scenes were as you say mostly sunny ones, your best possible exposure would have been close to 400 for a short development: you'd get clean shadows and controlled contrast...
So your problem is having exposed at +2: you just need a very short development... You could try Ilfosol 3 1+14 at 20ºC for around 8 minutes, and you can get very good negatives...
Cheers
Juan
If the shots are important, shoot another test roll in the same light, and cut it into four lengths for tests. Even a roll of 135 format would give you a good basis for testing.
