Waterman100
I started developing film about 3 weeks ago, and so far I have done an assortment of TriX, Acros, Arista, and Legacy Pro. I have just finished my first gallon of D-76, so I've done 16 rolls in all, I think.
After the initial two or three rolls, w/ some hit-and-miss, I adjusted my workflow. And now I'm doing two rolls each time in a 4-reel tank and also using a slightly longer time at 65F, instead of the standard 68F.
Using 65F is out of sheer convenience because 65F turns out to be a temp easier for me to obtain & control: tap water and ambient temp at this time of the year is such that if I mix stock D76 and refrigerated water 1+1, I arrive at a ~63 F solution.. From here I can keep it to 65F easily.
So far I have been getting good / scannable results. But I have nothing to compare my results to bec I am still inexperienced in this whole thing. My question is, what variations are introduced to the negatives by using 65F? Is this variation noticeable, or theoretical?
I've pretty much settled on my current workflow, and I'd prefer not to change it (at least for a while), unless it's worthwhile. What do you think?
