sojournerphoto
What is your work flow for scanning and have you experimented with changing the height settings of the holder?
Isuspect the poster issue is not holder height as he says it's sharp already. More likely the workflow is clipping balcks and whites and iving poor tonality. The nly way I've found to deal with htis is to be meticulous about setting exposure and black/white ppints. The the v750 can be made to give really good scans, particularly at the price. It's much better than I expected!
with respect to the earlier comment, the high resolving lens is used if you use a film holder and not the mask direct to the base glass I think. Hence you don't need to scan at 6400 and downsixe, 3200 will do.
Mike
