Try a yellow tape, it's awesome
danielmk2
4:29 PM
Hey guys, last week I put a yellow filter in front of my M7 and bang! The frame lines become yellow, and it seems easier to be seen in the dark. So I sticked a piece of transparent yellow tape in front of the frame line window, and it works great.
But somehow I realize that the brightness of the frameline is lower, but the color makes it "brighter"😀
Okay. So I looked at this and thought, "Yellow LED in front of the frameline windows". I did that for a Nikon DL-1 illuminator. Make the framelines brighter, and reduce possibility of RF patch flare.
Where's Tom A...
Where's Tom A...
I did that for the M5, where it's doubly useful for the meter readout - the meter scale can be hard to read already under lighting conditions wihere the meter still works fine.
Cool! Gives it a Euro look 😉
Good inventions are made many times 🙂
Petri RF's used this trick, too.
petri 1.9 color super_0872 by mondays child, on Flickr
Petri 7S by Green_Power, on Flickr
As well as on some other models:
http://www.on-photos.net/appareils_anciens/petri_19_ccs_2.php?id_marque=34
Petri also did it with blue tinted glass - Petri Blue Magic Scope, basicall very similar to model 7.
http://www.collection-appareils.fr/Petri/html/petri_blue_magic_scope.php
Bluish tint were used also by Yashica in Electro rangefinders, though internally, one couldn't tell from exterior.
So, if the brightness of my RF window is high (the contrast patch is barely visible sometimes), can I apply the same trick on my M2?
I guess different color will have different effect and taste 😀
This is what I use, transparent yellow sheet with adhesive http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160607399071&viewitem=#ht_500wt_1182
This method only affect the frame lines, the 135mm frame line is still white when the light source is mainly straight forward because some of the light for 135mm comes from another window. If I put a yellow filter in front of the small RF window at the same time, all the frame lines including the RF patch are yellow.
naruto, I don't think this method will help with your contrast problem of M2🙁
