I have this lens. The light falloff is a problem even with color negatives. Negatives have a lot more tolerance for overexposure, so I overexpose 2 stops to get the corners decently exposed. I can then use a circular gradient in software to remove central hot spot.
The same problem also occurs with the 21 f/4 Skopar. It gets less as that lens is stopped down. So, you may want to try stopping down the 15mm lens to f/8 to see if the corners will improve a bit.
An alternative with slides is to make two exposures (if the camera is on a tripod), and merge the two images in software. Of course, one exposure needs to be 2 stops greater exposure than the other one.
