Acetic acid stop bath
Rhodes
Time Lord
11:54 AM
Figueira da Foz, Portugal
Last thursday I went to my anthropologi department and end it, has always, goin to the old photo lad, now used for other things. I got a bottle of acetic acid for my father (he uses to store other kind of liquids), but this one is still almost full.
I thought using to do a stop bath insted of dumping the acid. So, can I do a big quantity of stop bath and go using, like the fixer? And the ratio is 1:3? Should I use destiled water?
Normally, my stop bath is destiled water, one minute, continuous agitation.
Why do a big quantity? Mix it up as you need it.
Assuming it's glacial, remember (a) it's corrosive and (b) Always Add Acid To Water (not water to acid).
Also, if the acteic acid is indeed glacial (meaning containing almost no extra water) then you can dilute it to only a few percent instead of 1:3. With any luck there is a label on the bottle which should confirm what is actually in there. That could be a couple of years of stop-bath! Of course there is no indicator dye in the solution if you work like that, so you can either use ph detector-paper, or use the stop bath only a few times - for either way, it needs to be acidic to continue working so eventually the alkaline developer carry-over will make it ineffective.
After Rogers essential advice about adding the acid to the water, there are extra mixing tips are here, among other places.
