problem changing ISO speed on F - Ftn metering head
yossarian123
Sam I Am
1:28 PM
Chicago
KEH just delivered my BGN F w/Ftn Photomic head, it appears that the ring to change the ISO speed is frozen. I read the manual, looks like changing the ISO speed is the standard way, just lift the ring around the shutter dial and twist until your film speed matches the red dot. My metal ring does not want to lift up, no matter how hard I try. Am I doing something wrong or do I just send it back?
Yeah, It should lift up maybe a 1/32" for it to turn freely...
See if you can insert your thumb fingernail between the metal ring and prism body to lift it...if not it sounds like it's stuck...
looks like a Photomic FTN, I don't see any lugs so I'm going to assume that you use the ring to change ISO. BTW,the serial is 711xx (on the metering head, not the body). But it's still stuck - would a drop or two of lighter fluid help to unfreeze it.
So it turns out that a squirt of Liquid Wrench loosened up whatever gunk had accumulated in the head. I'm off to test the meter itself now..
I didn't want to return it to KEH, it was a $72 BGN special and they didn't have any others at that price.
That is good, let us know how accurate the meter still is.
Bob
