Enlarging lens Visoflex III and M9
SDK
Exposing since 1969.
8:25 PM
Boston, MA
Hi folks, I recently got an M9p and have a Visoflex III on the way. I’m getting an Elmar 65mm and 16464K focus mount adapter too, which should be fun for starters. I have some nice enlarging lenses with M39 screw mounts I would also like to try for macro work (50mm/2.8 Apo Rodagon N, 63mm/2.8 EL Nikkor, 80mm/4 Componon S, 105mm/5.6 and 135mm/5.6 Rodagons). Is there an adapter I can get to use these with the 16464K or some other focus mount?
Any advice would be appreciated.
Thanks Jaapv and Roger, I’m getting an OTZFO (16464K), but I suspect most of the enlarging lenses are too fat to fit inside, being c. 40-45mm diameter. So I’ve found some Leitz extension tubes on eBay that I hope will fit and allow the lenses to work. I think I’d rather use tubes than a bellows.
