The El Cheapo Bob-Grip for RD-1
Status
Not open for further replies.
Roverbovver
1:45 AM
D-57271 Germany
I won't enter the discussion pro/contra grips but suffice to say I needed one in a hurry. Take an Olympus OM Winder, it doesn't matter either 1 or 2 will do and they're abundant. Remove the bottom half, most of the screws are pretty obvious. Two in the head just under your index finger are a little more hidden. Lift the head and cut the wires. Remove the battery box and seperate the lower half. A couple more screws and wires to cut and then you can remove the guts and motor.
There is a rubber buffer on the rear side of the handle. Lift this up or dig it out. There is a cross-headed screw behind it holding the raised collar for the rubber. File it if all else fails to get the grip to sit flat against the front of the camera.
There is also a pin that locates into a hole in the Olympus OM base plates. If you are feeling brave you can drill the RD-1 base plate to accept this. Please remove the base plate first, we don't want to go drilling into your Epson's circuits. If you choose this route the pin must me shortened. I didn't, I just ground it off flat, I was in a hurry.
The Epson base plate has four nipples, these lead your new grip to sit unevenly, use tape to balance this out. There is not enough thread on the screw to allow any generous padding between your grip and the base plate.
Look at the pics, make your decisions. A wrist strap from Luigi will provide peace of mind.
I have a problem uploading pictures, I'll get it sorted shortly.
for pics scroll down
as of 2.8.2013 the R-D1 is for sale see the classifieds and ignore the red SOLD text !!
RD-1 grip
RD-1 grip
I'd love to see the result here too. This forum will not accept photo uploads from me despite all parameters being adhered too. Mail to the administrator asking for help to solve the problem remain unanswered.
The grip ain't pretty and it turns your RD-1 into a Canon 5D but it fits and works well. Can send you pics directly if you give me an email. Bob
Same old problem. Error message: Quota exceeded. Despite having no attachments at all, anywhere, anytime. So no pics unless you guys want to email me. Or does someone have some ideas ? Forums survive on contributions.
Groan. Humour much appreciated, gotta lighten things up here. Thinking about this job further: it would take very little to make it neat, by a adding a plate in alu or plastic card, cut to fit the underside. Maybe even a tripod thread as well. The Olympus OM Winder I weighs 85g after modification.
Bob-Grip pics
Bob-Grip pics
Upload problem with " quota exceeded" error message still present. Cheers and congradulations read in other threads about the problem seem not yet called for. Very dissappointing.
pretty easy to upload to Flickr and link to your post. Non much more complicated than re sizing an image specifically for RFF.
You can install Dropbox and drop your images in the public folder. Control-click on the image and copy the public link. Pm your email and I'll send you a referral link.
staying focussed
staying focussed
Gentlemen, thankyou for all the input on how to 'band-aid' the upload problems of RFF. I don't mean to lecture anybody but there is a danger of going off-topic here. This was about a cheap and effective grip. The 'work' has already been put in by me. The effort and time involved was little longer than it takes me to type this. If you feel the need for a grip, and admittedly under most circumstances when I use this camera I don't, then get a duff OM winder off craig's/gumtree/ebay for 10 USD/Euros/Squids or 5000 Drachma. Hacking the winder was definitely more fun than viewing the pictures.
Bob-Grip pics
Bob-Grip pics
Well done gentlemen, the uploads now work, no more contradictory messages. Thankyou.
As for the rest of you, you can now see what I mean, not exactly the last word in elegance, but effective. Now what function could we give to that superfluous switch ? 🙂
This is pretty crafty! Maybe make some room for an extra battery and extra memory cards? 😉 expect these to go up in price now... Good on you for discovering! My guess is the nikon MD-e and MD-14 might work as well, the photoequip FM grip which was made for nikon FM, FA, FE fit fine on the r-d1 with very little shimming.
Status
