charjohncarter
I love the flash GN setting on the lens. The only camera I know of that compensates for flash that way. I always carry mine loaded with color film. It takes up very little space in any camera bag.
Here is a little thing I've worked out for using the Flashmatic feature on the 35RC, I got some of it from here:
http://www.ph.utexas.edu/~yue/misc/35RC.html
But you don't have to use the Flashmatic feature but I feel it is much more consistent than the Auto settings. Anyway this is my 3 favorite flash styles using the Flashmatic feature:
Olympus 35RC Flashmatic techniques:
Fill Flash: flash on manual, set GN
Set ring to Flashmatic, adjust distance by RF, half depress the shutter, read the aperture (say f5.6).
Set ring to ‘A,’ adjust shutter to give f stop plus two stops (f11).
This gives a proper background and subject ambient light reading while filling in the shadows slightly.
Beating the sun: flash on manual, set GN
Set ring to Flashmatic, adjust distance by RF, half depress the shutter, read the aperture (say f8).
Set ring to ‘A,’ adjust shutter to give the flash f stop (f8), now the tricky part set the manual f/stop to f/8 and remembering the ‘A’ shutter then up shutter speed two stops (say 1/125 to 1/500).
You are giving proper exposure to the subject with your flash while darkening the background.
Indoor flash with some ambient light: set flash on manual, set GN
Before setting the camera on Flashmatic, take an ambient light reading of the room using ‘A’ setting.
Now use your Flashmatic setting and try to get as close to the ambient light reading; shutter and f/stop, as possible without overexposing the background.
This gives your flash shots with some ambient light, your flash shots are not black in the background. When I do this I do it once say shutter speed of 1/30 and the leave it for the duration.
In more simple term: set to Flashmatic, set your shutter to a slower setting to bring up the ambient.
