Wierd problem
Jockos
2:15 PM
Sweden
When I developed a roll from my M3 today, one of the images had the wierdest look.
The image is taken with a CV 21, sun was dull/overcast, it's only this frame and and the problem is clearly visible on the neg.
HP5+/D76
Anyone?
Light leak!
Any play in the bottom plate? Or in the back door?
This looks like a typical M light leak, which is coming from the front, not the back. If you had a recent cla, they may have disturbed some light seals or baffles. Often the light is coming in through the finder.
If you shoot a roll of color film and get the leak again, you would see a white leak if it is from the front, and reddish one if it comes from the back. It does look like you will be sending it back for repair though.
Bummer.. I should be able to try this out with a flashlight right?
Pretty weird tough that it only affected one frame in two rolls.
If this is an actual scan of the length of film, I wonder why there is uneven spacing between the frames - don´t know whether that could be an indication of the cause for your problem....
The tech guy said that the frame spacing could not be adjusted during the CLA. And actually it was a bit better before the operation.
