Pen-F halfframe are being tested and used on Sony A7 FF cameras. Looks like the long lenses are fully useable, the 'normals' just about, the wide angles produce definite dark corners:
e.g. a flickr set of photos taken with 1.8/38 on A7:
https://www.flickr.com/photos/110548103@N07/sets/72157646594578645
the 1.4/40 on A7:
https://www.flickr.com/photos/padiej/sets/72157645855701295
the 1.4/40 shows strong vignetting, it's fine at 24x24mm, always shows it's very good sharpness! The bokeh of the 38mm is 'lively' that can disturb, but here often enhances, is used to make the image.
Jim, why not use CV lenses instead? You are right if you need more reliable performers. Why use vintage lenes at all? Pen-Fs are older and different, some say have limitations, others say charms. They usually cost less than comparable CV lenses and have a much shorter minimum focus distance. I'd say they are lovely and high performance lenses, I am quite sure that at wide apertures the Nokton 1.4/40 isn't anywhere as sharp as the Pen-F 1.4/40.
Sebboh decribed the 1.2/42 so very well and detailed, most I consider also true for other Pen-F lenses, good shaprness, flare problems, funky bokeh, wide angles impress me with little distortion
from left to right: 3.5/20, 4/25, 2.8/25, 1.8/38, 1.4/40. 3.5/100, 3.5/50-90, behind mounted on Pen-F 1.8/38, on NEX5N 1.4/40
( the 1.5/60 came later, 3.5/20 and 2.8/25 seen had been somewhat faulty, replaced now with good copies )
Obviously I like the Pen-F lenses, now converted them to Leica M to use them, besides on NEX5N, on Ricoh GXR M.
The updated list of the sets, each dedicated to photos taken with a specific lens:
3.5/20:
https://www.flickr.com/photos/kuuan/sets/72157647002683101/
3.5/20 faulty copy: ( paint on rim of inner lens element had 'evaporated', lead to some 'blooming' )
https://www.flickr.com/photos/kuuan/sets/72157628125919493/
2.8/25:
https://www.flickr.com/photos/kuuan/sets/72157647206708242/
2.8/25 faulty copy ( coating damage on rear glass, problematic against light )
https://www.flickr.com/photos/kuuan/sets/72157629419646160/
4/25mm:
https://www.flickr.com/photos/kuuan/sets/72157629897212327/
1.8/38:
https://www.flickr.com/photos/kuuan/sets/72157627988053181/
1.4/40:
https://www.flickr.com/photos/kuuan/sets/72157629315399105/
1.5/60:
https://www.flickr.com/photos/kuuan/sets/72157631525848244/
3.5/100:
https://www.flickr.com/photos/kuuan/sets/72157628364071135/
some ( a bit random ) examples:
3.5/20 on Ricoh GXR M:
2.8/25 on NEX5N
4/25 wide open on Ricoh GXR M:
1.8/38 on Ricoh GXR M
1.4/40 wide open on NEX5N:
1.5/60 wide open on NEX5N:
3.5/100 on NEX5N
