River Dog
Always looking
My Rolleinar 1 has a little fungus spot inside. Has anyone ever cleaned one and how?
I think the black ring at the front unscrews but I don't want to try to hard until I know for sure.
Dan Daniel
I've looked at images of a Rolleinar on the web but can't see an entrance point. Any chance of posting close-ups of the front AND especially the back side?
As I understand it, the prism element is at the front of the viewing lens rolleinar (and I am assuming that your fungus is on the viewing setup). Meaning that unscrewing the front black ring could lead to a misalignment of the prism on re-assembly. I think that going through the back to remove the actual close-up element for cleaning will be safer. IF there is a back entrance!
I recently bought an 'ACCURA' close-up lens for Bay I that has a prism for the viewing lens. There are set screws that hold the prism in place, but they were loose on my copy. I viewed through the lens and rotated the element. You'll see the image shift in an arc; I just stopped when it appeared to be at the top of the arc (or the bottom??? confused and don't remember the specific, but you'll see the image moving).
hanskerensky
Just had a look at my Rolleinar 1.
The taking lens as well as the viewing lens have a black ring at the rear.
Each ring has 2 slits so guess that those rings can be removed by using
a "normal" lens spanner.
However i have no intention of testing this out on my own Rolleinar.
Would be wise to mark a glass (soft pencil) before you remove it as i
don't know how easy it is to accidently re-install it the wrong way around.
And i agree with Dan, better not remove the front element of the viewing lens.
River Dog
Always looking
Thanks for your comments. I'll take another look and post some close-ups here.
