ron klein
trying to code a 15mm voigtlander with m-coder with no success. using tri-elmar 16 18 21
any help out there
any help out there
It works, but I have to select lens recognition with UV/IR. Selecting Lens recognition without UV/IR does not seem to "take."
That's the way to do it. The software of the camera eliminates the magenta faults in the corners to some degree when using UV/IR filters. There is no sense for correction if you don't use IR-cut filters. Btw works only with (super) wide angles.
I dont belive the WATE is the best to use for correcting color shifts for the CV 15mm. IMO the 21/2,8 works better. But its even better to use Cornerfix and no coding.
From left to right wtih the back of the lens facing you... 3 whites 2 blacks followed by a white. You don't need to colour the whites in other than the second indentation which is where the screw is located. You can fill it in with white nail polish, tape or something similar.
I assume you turned on the lens recognition in the menu setting area...
Best Rob
Sorry to stick my oar in, but l've got mine coded as the WATE and it works absolutely fine - however, mine appears to be coded as one white, one black and four white ! I could be wrong, but is that not the code shown on the link from Sean Reid's site ?
philip
Best Rob
My Match Technical Coder Kit shows, for the WATE (going left to right), four whites; one black; and one white. That is the order that one sees with the coder template in place, and the part of the lens to be coded facing (nearest to) me. That would appear to be the same as you said, Philip, only just stated in reverse order.
Here's what I got when coding the 15mm CV as the WATE, but without using a UV/IR filter (I don't have one yet). The camera was coded lens detection "ON" with UV/IR filter. It's just a tiny crop out of the frame, showing the artificial colors that resulted in the roof area. Most of my shots have been great, without problems.
