L David Tomei
- Local time
- 10:13 PM
- Joined
- Dec 3, 2007
- Messages
- 363
The voltage, the type of plug and polarity of the contacts are the only important things. If that's known , then almost any DC power supply can be used.
Right. But in this case the power supply is the good part. Something has gone dead in the drive itself.
The biggest seem to be Kroll Ontrack.
MY WD uses an external power supply, which is good--it measures 12VDC at the plug
I have two Western Digital external drives for storing pictures. They have about 85% to 90% overlap in content, with each one backing up the other. The earlier one quit working. From Western Digital's website, it looks like they don't offer a repair service. However, they do mention that there are data recovery services (although WD doesn't seem to offer this).
Has anyone had any experience with data recovery? Or getting hard drives fixed? Where does one go for this?
Lacie makes external drives and the 2 tb got a good review on CNET... however, I can only hope it's good.
My bad drive was recovered by my wife's friend at her school and it wasn't difficult, but then I didn't do it. He also recovered an entire pair of drives on my old computer as well. Can't imagine why it would cost $1000 to do it.
First take the HD out of the housing. Power the housing and proceed as follows:
Where do you measure this 12VDC? If it's IDE type, then there is a 4-pin supply socket inside the housing, yellow 12VDC, red 5VDC you must measure. If SATA type then measure the same not on the narrow data socket but on the wide power socket. If the voltage could not reach to the sockets as stated then a. short circuit the switch b. test all 0 ohm resistors (fuse resistors) from the input of 12VDC.. (follow the +) Test them as diode.
Depending on your findings I will try to assist you..
I got it out of the case and found the socket with two black leads, a yellow lead, and a red lead. I got no voltage reading from red to black and none between yellow and black (or between any two leads.) Same thing after pressing the switch. I see some resistors--the smallest I ever saw--on a small circuit board, the same one the switch is on. Should I go ahead and measure them with a DVM? Or with my Simpson 260XL on the low-power ohms range? They are tiny! I hope I can get my test leads on them! And I hope they are the right ones to check.
Buy another hard-drive caddy and try the drive in there. They cost very little and if you find the hard-drive itself is dead, then you will probably want to put another disk in the caddy and use that one anyway - so the small cost is not wasted. Using hours of time to diagnose an non-repairable component is not sensible.
This is not the place to get reliable advice explained at length, so that you can understand what you are trying to do and the ways developed in industry over decades to solve these problems.
All hard-drives, and caddies, and PC's (and Mac's) etcetera, etcetera, come with a 100% guarantee of failure. The only question is when. Remember, 100% - ALL of them.
Please put these three paragraphs together and realise that you would do well to ask around your locality for a specialist shop or contractor to help you out! 🙂
