karlori
Digital Refugee
No... if I'm scared to use it, I won't own it. I find it silly to own expensive lenses (gear) just to keep them on a shelf (unless you are a collector and not a photographer). It's just equipment. Then again, I don't use hoods or protective filters either.
Are you guys that are scared that clumsy?
I sneezed onto my new EF 85 1.2 L ten minutes into my first photoshoot with it... And I was always scared to use the 70-200 2.8 IS because of the weird grinding sounds when the IS engaged or disengaged...
