Agfa Isolette
mgchan
Back To Film
2:58 AM
NYC
I finally found time to get this Agfa Isolette folder working. I'd acquired it a few years ago and it was a mess. The usual problems with these old folders... the grease had turned to glue so it couldn't focus, and the bellows could've been used as a sieve. The kicker was the guide pins were broken off, so the lens part just flopped around and there was no tension on the bellows when it was opened. So it had just languished on the shelf collecting dust.
I'd used book cloth for both sides of the bellows, so it's a bit thicker than it should be and stiff. Since it's my first bellows, it's not exactly even and straight in the right places, but it does the job!
Here's a few shots from the first test roll using Ilford HP5:
When using this camera, one just needs to make sure to set the distance correctly :bang:
Plus to set the shutter before taking the shot instead of setting the shutter after each shot. Otherwise one can accidentally trip the shutter while opening the bellows 🙄
Be proud, you have brought wonder back into the world! Thank you for posting this AAAAAND with photos as well. That's how it's done!
All the problems were fixed. I'd re-lubricated it with lithium grease and re-adjusted the focus. It's a neat little folder. Very easy to carry around and use, even without straps.
I was very surprised at the results! I was expecting super soft photos.
Amazing how much of that high price snobbery is BS, isn't it?
There is all kinds of internet wisdom out there that is just a bunch of dummies repeating other dummies who are repeating other dummies who are repeating someone who made it up.
My ex wife used to ask, "How did you learn how to do that? Oh, wait, I know you read a book". What she missed was: I read the book, then tried it. If it worked, I went through the hard work of learning how to use that knowledge. Many of the books I read were written my people who had never done what they were writing about. It is easy to read something an think you know all about it, but until you actually try to do it, you do not know anything, you are just repeating some idiot's opinion.
In the end, we only learn by doing, as you have with your Isolette. Hearsay is not knowledge despite what schools seem to think.
Fixing and using this old school folder makes one realize that even a basic and inexpensive camera as this can produce wonderful results.
Looks like you did a great job with the bellows. Those old folders can still deliver great photos.
Would you consider a DIY on how you did it in the camera repair forum?
The bellows look good and it looks like they are doing their job!
And nice pictures from the simple Agnar lens!
Which aperture are you using at it?
I am looking forward to use my Agfa Record with its Apotar lens which got its shutter release repaired last weekend 🙂
Thanks for the wonderful feedback and comments.
I have short term memory, so unfortunately I don't remember the settings. 🙄 For future shots I'll have to make it a point to write down the settings.
I was able to repair this camera from existing DIY links, but it may be fun to pickup another camera and document the entire repair process on RFF.
The bellow looks great!
I came upon this thread looking for some tips on the agfa compact folder cameras. My friend just loan me on that she's never used. I think it has the same Aganar lens 1:4.5, 85mm. It says Vario on the ring. The shutter fires, but the distance wheel doesn't turn.
Any idea where to look for solutions?
Thanks!
Thanks Thomas for the info and the link to the thread. It looks and sounds a bit advance for me to do. Once again though, the Rangefinder forum had not just the answer, but such detailed how-to!
Welcome, HLing, to the wonderful world of Agfa/Ansco. If someone ever gets one that doesn't have a frozen focus, it's a rare thing. Or someone has worked on it recently. I just picked up an Ansco Speedex Special "R" (same as Agfa Isolette III), and it's in need of a total rebuild, such as what mgchan did to his. And someone showed me his Isolette the other day that had the bellows from a Zeiss Nettar for a replacement. It kind of tempts me to do the same, but the Nettar is in much better shape, especially since I just overhauled it. However, the "R" has an uncoupled rangefinder, and that's what is making me think about doing the swap.
And congrats mgchan on getting your camera repaired. You did a good job on the bellows for your first try. I still haven't gotten to that point yet, mostly because I have been able to seal most of my leakers from the inside with fabric paint. But I've got too many Agfa models now to get by with that much longer.
PF
PF
i wouldn't want to destroy a decent camera in good condition to make another functional, its kinda like destroying history, one day, maybe not for many years yet but sooner or later they will be hard to get and you just destroyed one, to make another work (hyper... speaking). as Nik has shown making bellows is doable, kudos to him. there are bunches of tutes on how to make bellows and lots of books, its tedious and time consuming but quite doable, getting the materials is about the hardest, shutter curtain material (from places like microtools etc) for the inside and ultra thin for the outside is obtainable with some searching..bellows can be purchased from a few ppl as well..save the old camera, make some new bellows for a agfa 🙂
cheers
chippy
That's okay, chippy, I talked myself out of it already. However, I do need to flip the center element back to it's proper orientation. Thought I had it in wrong the first time, but man, does it give some weird results that way.
PF
4973378185
Hopefully I got this to work ! This is my 1956 Agfa Isolette III I was given by a Lady Camera Club member -- it has the 75mm f3.5 Solinar lens, Synchro-Compur shutter, un-coupled rangefinder -- I find it better for closer range photos to set a distance on the lens first, say 1.6 meter then set same distance on the rangefinder, line up the subject and 'sway' back and forth watching the two images -- when coincident I release the shutter !
Isolette III by pentaxpete, on Flickr
