Caffenol Out of boredom
Tom hicks
2:45 PM
Dallas Texas
Well I finally did it, after some 8 months of thinking about it. First images are from Tmax 400 using the Delta STD recipe.
Second set were with the same recipe but shot with Ektar 100.
Now did your negatives turn out with a tint?
I'm all for Caffenol and was considering playing with it when I get the time.
Awesome results btw 🙂
Corey, my neg came out looking like they would have had I done them in the normal way . They scanned and looked like any other B&W negs . I use a Coolscan V. , was very easy . Coffee cheap stuff $2.99 8oz , Arm & Hammer super washing soda $3.29 55oz, Vitamin C crystals GNC 160z $29.00
I think the tint comes from when you wet print using caffenol as a paper dev and or the red wine recipe.
Thanks for the info Tom, been looking for organic ways to develop since my mom hates film chemicals (No developing in the house ect....).
Best part is - my dad's a mechanic and what he has in the garage is worse 🙂
He supports it, as he used to do the same with his Nikon F3.
I will be doing some more research!
Excellent photos, Tom. I've not had much luck with Caffenol yet. Very thin negs, but the water temp turned out to be all out of whack.
Larry I had thin negs too, then increased dev time another min and they got better. the first roll I did had very dense negs .
Using the delta std formula http://www.caffenol.org/2010/03/12/the-delta-recipe/
7min thin negs , 8min good negs, 9min dense negs . this is with ektar 100. 9 min with Tmax 400 worked good.
Tom, you said "ektar 100" above. Are you referring to the color negative film?
Yes all color film turns into b&w I could not find a specific recipe for extar but through dev. ten frams at a time I found out that the delta formula works good at 8 min . Constant inversions for the first 30 sec then 4 inv, every min afterwords, stop bath with water then fix as normal. The same recipe also works well with TMax.
Here are a few more from the ektar. I shot it at 50 iso Another member said the pics look like they were shot with a blue filter because it darkened the reds. I have never used any filters so never really noticed the change .
Do you still end up with an orange mask for color neg film processed in caffenol? Does your scanner remove that, or are you removing it in post processing?
