Is the difference in score a lot in reality? Doesn't seem so to me.
11 stops of dynamic range is very low for a FF camera. For example Panasonic LX3 P&S has an 11 stop of dynamic range. 12 stops for RX100 is normal for current compacts.
For actual use pixel size and resolution of a full frame camera makes all the difference.
Not, it really isn't. But, even if there was no difference at all, it would've been unthinkable a few months back. If these results are true, my hat's off to sony. That's a 12.4EV dynamic range at the lowest iso from that tiny camera!
with DXOmark you can only compare cameras with same sensor size, I read of it somewhere.
you can't compare the test results of a full frame camera with the ones of a little sensor.
they should have a similar pixel density too.
in real time use the 5d2 will outperform the rx100 in every possible way though except for maybe AF performance.
