Leica LTM I have to get a screwmount
Have you considered a Rollei 35 ?
Think about it: it has everything you want plus brightline in the viewfinder and meter, a great lens, is smaller and certainly more robust than a Fed. And probably will be cheaper than getting a working Barnack or copy with finder. They came in black too.
Plus one for the Rollei 35. Do your research, and you could getr it cheap!
To give you an idea of the relative size, here's a Leica IIIc and a Rollei 35. I took this combination on a 4-day trek in the Sierra Nevadas in August, and it was perfect. Makes a great combination for general travel, too.
photo by bingley0522, on Flickr
If you're really broke, I recommend this camera. It can be had for $25,
or even $5 at a thrift store and takes wonderful, sharp images.
+1. An indispensable pocket cam, and punches well above its weight in terms of image quality.
Sample Picture
Sample Picture
I'd parked the car and saw this. I only had the Zorki 1 with me and it had the standard lens on it. I used the Sunny 16 rule for the exposure and the scan came off of a cheap CD from the lab that I use for cataloguing the pictures.
It shows what a nice lens/outfit you can get for very little money.
Regards, David
really nice combo. Found a Rollei 35 black in local craigslist guy asked for 375 so no thanks its not german made one too ..
yep, bessa L if you want to actually take photos, having said that I keep a IIIa/f with a summitar on it in the car's glovebox all the time without any problems
wish it was 160 dollar cheap.
Rollei is 90 dollars i found a decent shaped one
and the original barnack that needs a cla i found for 200 with a good shape lens
