Post your Fall Foliage (and was that a Leica or a Zeiss . . .?)
Benjamin Marks
9:02 AM
Vermont
Self-indulgent fall foliage bokeh-paloozah pix follow. The top two images are from the same 50mm lens wide open and at f:2, the bottom two are from a different 50 wide open and at f:2. One set is from the Zeiss M-Sonnar, the other is the current Leica APO Summilux. All pix taken on a Sony Alpha-5 at base ISO with a Hawk helicoid adapter. Imported into LR4 as DNG files with default adjustments and exported as 8-bit JPGs.
Post your fall foliage and for fun, and as a bonus see if you can guess which lens took which pix. Full disclosure: I moved the tripod inbetween exposures so the point of focus is not identical for the two sets.
Image #1
Image #2
Image #3
Image #4
Let's see some fall!
Here's another contrast. Top picture is a Nikon D3 with a 50/1.4 Planar at f:2.
Next is taken with a Leica M9 and 50 Asph Lux at f:2.
Nikon:
Leica:
Interestingly the Leica file needed a tweak to the white balance. I didn't want to do it, because it makes an A-B comparison more difficult, but I rationalized the tweak by telling myself, any comparison like this is really about the lenses. Of course, it is about the whole systems. Leica: ISO 160, D3 ISO 200 - -the base ISO's of each camera. It was an overcast day and the Leica file out of the camera was waaay too warm.
