Dear Kenny,
In your case I'd back the third and fourth options.
Thanks for your reply again! I wanted to get back to you on that specific part though that I have quoted here. So, you think it is more probable that I am making mistakes either when developing or when scanning rather than when exposing? This might very well be the case, which is why I have a few follow up questions:
1. To me, I imagine that my negs should be somewhat more dense because I can quite easily see through even the highlight parts. Somehow I imagine the highlights to be a bit more opaque than what I'm getting. Also, it just seems to me as if I have a bit too much transparent film on the negs, more than there should be black in the scene. This has lead me to believe that I am underexposing, because the negs don't seem extremely flat, rather just thin.
2. I have been developing based on the Massive Dev chart as I've heard good things about it. However, with the specific developer I'm using (FX-39) there are some revised times and alternative dillutions, and seeing that I'm new to this I'm not sure how to relate to this in regards of my specific developer.
3. Lately the weather in Sweden (or most often really) is pretty overcast, so I don't usually get very high contrast scenes unless it's summer. Lately it's been more like a giant soft box than a blue sky. Could it be that the combination of this flat light and the compensating FX-39 (as I understand it) leads to me getting underexposed/flat negatives?
I have been thinking that I should try Rodinal or something which everyone seems to use, instead of messing with something that isn't as common as it seems, at least now in the beginning.
Based on the FX-39 fact sheet I am actually agitating more than it says, and my understanding is that it should help the highlights and contrast, yet I'm not seeing huge contrast in the negs.
My problem is that I've read up a lot on the process, and I like to think that I have a good grasp on the theory. The thing is just that what I get out of my development I can't really compare to anything. I'm not sure exactly what a "good negative" should look like and so forth. There are a lot of variables for me because of this, and it makes it hard to adjust the process as I am not sure where to make the adjustments.
If I take a digital shot of one of my negs, does that even make sense to show here? Could more experienced people based on that tell if it is underexposed, under developed, etc? When I look at the negative, and think of it in terms of the scanning process, I have a really hard time imagining that it's so dense that the highlights would actually go white because they would block the light from the scan head.
EDIT AGAIN:
Now I just realized that you are refering to option three and fourth of what you we're listing, and not what I was listing in the previous post? That kind of makes sense to me now in the context of this discussion.
🙂 So you are saying I should maybe try both thinking harder on what I'm metering, and perharps also try shooting at EI200?
