Rvl
What is the weight of the Perkeo II?
I found a pic online comparing the Perkeo to the Moskva
Yes! That's what's best, add simplicity. Yes 🙂....
The Perkeo came to me as two cameras. The film count/stop double shot prevention was demolished on the Perkeo II and unrepairable. However, it had the Color Skopar front standard, and the lens in Synchro Compur to 1/500th. I combined the two and did away with ALL the shot prevention, and film count/stop system. It became a totally reliable, very good 6X6 everyday shooter. No complexities and I use the ruby window for advancing the film, hence NO problems with frame spacing.
The hood on the Perkeo is OEM Voigtlander, slip on and rotates with the front focus cell. Since there are no guts and gears under the top plate, I know I can count on this camera to shoot every time, and for film to be in the right place. It's a very simple work flow and followed properly works. I never advance the film or cock the shutter on closing. That's always the first thing I do when I open the camera front door/bellows.
All compact and modern MF-cameras have already been mentioned.
- Plaubel Makina 67/670/w67 (folder)
- Fuji GF670/Voigtländer Bessa III (folder)
- Mamiya 6/6MF (coll. lens)
- Fuji GS645 (folder)
You can get excellent results with a great number of the older, simpler folders. But as others have mentioned above, viewfinder size would be smaller than is customary with more modern gear, it depends how the trade-off works for you.
Put these on the kitchen scale just now:
Voigtländer Perkeo II - 540g
Leica M4-2 fitted with Voigtländer Color Skopar 35mm f/2.5 - 687g
Voigtländer Bessa III - 1,021g
Hmm. Maybe tomorrow I'll snap a few comparison photos of the three cameras above, particularly the Bessa III vs Perkeo II.
I am a bit partial to my little Ansco Speedex Special R 6x6 folder for the same reasons. Light, compact, uncoupled rangefinder, w/nice, sharp, 85mm Apotar lens. Does a nice job without weighing you down. My Super Isolette is also very nice but seems to weigh considerably more than the Speedex.
