Sonnar Brian
Metering is via the Sensor only and a Sandwiched cover glass is used.
Noise levels are affected dramatically by sensor temperature. In rangefinder mode, the sensor must be active just to provide metering. Sandwiched cover glass is a technique used to combine a glass with properties affected by humidity with a protective glass used to shield the bottom layer from humidity. Such as using S8612 with a BS7 cover. Maybe Leica has a different reason, we'll know in a few years if the bottom layer starts corroding like on the M9.
