I have a coated nickel Tessar 1:2,8 f=5cm Nr 130815 (Contax mount). The coating is blue. The lens is however unusuable due to scratches. It seems that only the front lens is coated.
Erik.
Erik- are the scratches limited to the front element? The Certo Dolina also used a 5cm F2.8 Tessar of similar design, and the front optic is interchangeable with the original Black/Nickel Tessar for the Contax. You can also use a later front element from the Contaflex 1.
