Retro-Grouch
You are correct. I take mine out for a shooting session when I don't have the time for a good flogging.Did these things sell at all? Sounds like it'd only appeal to real masochists. 🙂
I sold my Minox enlarger long, long ago now, but still shoot with Minox 8x11 fairly often. They're wonderful cameras, so small and precise!A few years ago I saw one of these special Minox 8x11mm film enlargers behind the window of a local photo shop.
But since I don't have a darkroom, I only develop black and white films.
The negatives are then scanned, and I still have to learn how to produce reasonably viewable images for my screen from the tiny 8x11mm format.
SONY DSC by Nokton48, on Flickr
SONY DSC by Nokton48, on FlickrYou can probably modify the infinity catch so that it stays down, easiest way- use something to hold the pin that detects external mount lenses in use. Remove it when changing internal mount lenses, or modify the mechanism that causes the infinity lock to move back into engaged position. I might have done the latter to two cameras, at least one that I have.The thing of the Periflex that annoys me the most is the fact that you have a separate wind an cocking mechanism (though they're linked to prevent double exposures).
I'm a Leicaphile at heart, but my Contaxes II/III IIa/IIIa have grown on me. It's the infinity lock that gets me though! 😉
360mm f5.6 Schneider Componons matched pair 4x5 by Nokton48, on FlickrVery good. How do you like the Polaroid Go so far? I‘ve been hesitant to get one because initially the camera and film was hard to find. Now I’m seeing them in stores more frequently.…
Getting good results takes some effort. I have a few of my Minox photos posted on Flickr:
Flickr Search — “minox”
www.flickr.com
Well, speaking of masochism -- do others have the same problem I do with adjusting the film speed on a Nikon FTn? That dial is absolutely brutal to get to turn -- much much harder than the F2 (or any other camera with a "lift and turn" film speed adjustment dial).
All of which explains why I never even bother trying to hand hold mine below 1/250. Otherwise, with that limitation, a delightful camera to use, and about as pretty as they come!Odd is as odd does. So I'd nominate my former Bronica S2A: from the outside, an easy-to-use, generally reliable, and very effective 6x6cm SLR. But on the inside, the way it works is absolutely nuts, all driven by Zenzaburo-san's insistence on making a medium-format SLR that had an instant-return mirror long enough to avoid vignetting, and could use wide-angle lenses without locking up the mirror (all three of which characteristics were lacking on Hasselblad of the same era.)
Somebody correct me if I've omitted any steps from this ingenious but insane procedure, but as I recall it, it went like this:
To clear wide-angle lenses, the mirror doesn't flip up as you take a picture (and isn't split, as on earlier and later models.) Instead, it slides down and forward just before the shutter fires, so it winds up lying on the bottom of the mirror chamber with the reflective side facing up. It accomplishes this complicated motion via a cloth tape glued onto the back of it; when you release the shutter, a transverse roller across the bottom of the camera spins rapidly to wind up this tape, pulling the mirror into the down position.
Well, you can't very well have a shiny mirror lying on the bottom of the mirror chamber, can you?... it would cause reflections like crazy. So there's a thin metal baffle in the back of the camera, hinged at its bottom. Normally it's held in place by the mirror, and when the mirror slides down a weak spring flips the baffle forward on top of it.
Okay, but you still have light flooding in from the top via the focusing screen, right? To fix that, there's a fabric blind, like a little window shade, rolled up on another spring-loaded roller at the front edge of the focusing screen. When the mirror slides down, two fabric cords attached to its corners pull down with it; they run around little pulleys to pull on the fabric blind and unroll it to block the focusing screen.
After all that, the auto diaphragm stops down and the conventional cloth focal-plane shutter in the back fires, making your picture. Then the bottom roller releases and the whole sequence above reverses, resetting everything to the starting position. You then re-cock the shutter by turning the film advance knob and you're ready for your next picture.
The really amazing this is that, while the sound it makes is indescribable, all this mechanism operates pretty quickly, so the camera feels fairly responsive. And, since the S2A has hardened winding gears and a sturdier locking mechanism to fix the occasional winding problems of the previous S2 model, it's all actually pretty reliable... as long as that tape on the back of the mirror doesn't come unglued (which, to be fair, almost never happens). An animated film of an S2A's internal operations would be a nerd hit...
The later Nikkormats -- FT2 and FT3 -- have an improved mechanism from the earlier models so that the little film speed slider doesn't beat up your fingernail the way the FT and FTn do. But even the earlier Nikkormats are a walk in the park compared with the Nikon FTn. (I have several of these and they're all a trial. Maybe they're just in need of servicing, but more likely, the spring is just too strong.)(at first I thought you meant Nikkormat FTN rather than Nikon F Tn)
Nikkormats are inexpensive enough that you could by several, each set to a different ISO! 😀
In my case, I’m almost always using an ISO 200 film, regardless of camera, so I don’t change ISO settings often (even with digital!).
Thank you for sharing your experience with the Exakta Varex and your photographic journey in Australia. It sounds like you had quite an adventure with that camera and the landscapes you captured along the way. The Exakta Varex, with its quirks and challenges, certainly made for a memorable shooting experience.Yes, another "silly little thread" as a party pooper commented elsewhere on this site. But we live in miserable times (= Covid) and a little fun is surely welcome.
With this in mind, let's go with a thought I've had about old photo gear.
What is the oddest, quirkiest, or most unusual camera you have ever used? Whether you liked it or hated it isn't a concern - the oddity, quirks or 'unusualness' of the beast will be the one and only rule.
For me, it was the Exakta Varex.
In 1974 I traveled to Australia - I now live here, but this was my first visit to the wonderful continent I have called home since 1976 - via a roundabout way, Vancouver, San Francisco, Los Angeles, San Diego, Honolulu and a long, leisurely hop to Sydney via a half dozen Pacific Ocean islands, notably the two Samoas where I stayed the longest and enjoyed myself most. Also Guam, a long, long detour for me but so well worth the effort.
Anyway, when I flew out of Apia, the Samoan capital, I left behind my Rollei TLR kit and 40 rolls of film, at that time was my entire photo arsenal. (All the gear and film later returned to me in Australia, so it ended well.)
So I was in Sydney, without a camera. A friend took me to the legendary Grace's Pawnshop on Victoria Sreet, Pott's Point where for about A$100 I acquired an Exakta Varex II (or a IIb, memory is a little hazy after 47 years), a '58' (a Jena Tessar?), a few filters and an ancient leather camera bag with a sticker from a long-vanished Russian camera store in Shanghai, China. Les Grace kindly threw in ten rolls of ancient film (I think Ilford FP3) and directed me to a photo shop where I bought 20 rolls. All for not much money. The good old days.
I then acquired a 1950 Rover sedan with the dimensions and handling agility of a Sherman tank, and set off on a long drive to Cairns in what Aussies like to call the 'Top End' - 2500 kilometers one way, so twice that in all. Petrol (=gas) cos about 40 cents a liter then, and good seafood lunches at any pub in Queensland about A$2.
It took me about six weeks to get to Cairns in that awful car. Half a century ago (almost) Queensland was nothing like it is now, unspoiled and with eye-dazzling natural landscapes, mangroves teeming with bird life, palm trees and bamboo groves everywhere, not the soul-shriveling dormitory suburbs, shopping malls and retirement villages one sees now.
I shot all my film and bought more in Brisbane and also from small photo shops in the country towns - yo, those happy past times when buying film meant dropping into the local chemist (= drug store) for an assortment of color or B&W emulsions.
On the minus side, that Exakta drove me almost insane. One needed at least basic engineering skills to make sense of the quixotic (or idiotic) speeds, also at least one extra finger on each hand to comfortably use the beast. A third eye on one's temple would also have helped, with a retina magnifier to make good use of the squinty Varex viewfinder. Mine had the flip-up/flip-down Rollei TLR variant viewfinder and I had to either use the camera at chest level or flip up the direct finder and squint into a sort of mini-telescope.
I ruined my first few films and had to reshoot scenes on the drive back until I worked out to operate this crazy creature of a camera. To its credit, the thing worked best after I preset it and used it as a point-and-shoot. The lens was razor-sharp and made beautiful B&W mid-tones but not so great color negatives. I would have shot slides but even in 1976 E6 emulsions cost serious money in Australia and as for most of my life, I was on a restricted budget.
The 1000+ images I made print well to this day. I did go overboard on lovely landscapes of sugar cane and pineapple plantation and stunning sunsets on beautiful beaches.
Back in Sydney I retrieved my Rollei, sold the Exakta back to Grace's and went off to Southeast Asia via Melbourne, Adelaide and Perth. I ditched the Rover and traveled by train across the Nullarbor desert, a journey I enjoyed back then but once was enough for this lifetime.
One of the applications that support life a lot by answering questions you encounter is Chat GPT Nova AI Mod APK
Being me, I sometimes wish I had kept that Exakta. It was one of few cameras that made me really work for my images. Truly, it was East Germany's revenge on the capitalist world...
My little shirt-pocket Konica-Minolta DiMAGE X1 from 2005 has this feature plus several variations of it. 8 MP. That feature has been useful several times for me with sporting events. I still use the camera and can still get batteries for it!… the idea seems to be that you set it recording (it loops continually, over-writing what it has in memory, retaining the latest segment), then you click to indicate that the event you want to analyse has occurred - batsman hitting a ball or whatever.
Ahaha - I may have to talk myself out of looking for one of those now then... that sportscam is massive.My little shirt-pocket Konica-Minolta DiMAGE X1 from 2005 has this feature plus several variations of it. 8 MP. That feature has been useful several times for me with sporting events. I still use the camera and can still get batteries for it!
