tortellini_man
i just got a 35S and have been liking it so far
not sure i would want to pay >3x the price just for autofocus though
Hell, these are truly wonderful. Especially love the gypsy one. I need to acquire a Hell's Angel.
Would think that would involve designing and building it themselves. A lidar based system is likely off the shelf and just about plug and play to integrate it with the microcontroller in the camera and would be much less expensive and very likely smaller too.Wonder why folks don't consider using an infrared focusing system from something like the Hexar AF instead of Lidar. The biggest achilles heel of every AF P&S is missed focus. That's why I generally don't use them. Too many "focused behind somehow" the centered subject photos to count. if the Rollei can't be 95% accurate in real world situations, then it would never be for me.
Zeiss is absolutely not going to give the license for the name of one of their most famous/impactful lenses they have ever made to some tiny Hong Kong upstart. Not a snowballs chance in hell. They didn't even do that for the revival Rolleiflexes (FX/GX) which again share the same Planar lens structure but could not have not the name. And that Brand has been long associated with Zeiss and Zeiss lenses.... so yeah.It seems strange for the lens to be just a "Rollei Lens.". I'd like it to be a Zeiss Sonnar or Zeiss Tessar like the original Rollei 35. So that there could be more of a feeling of continuity with the original ones, some idea of the imaging. I'm sure it's good, perhaps a Cosina; but "Rollei Lens" seems unsatisfying.
Agreed. I find myself liking the concept of a compact camera more than the reality of shooting them. It sounds so nice on paper, though!Wonder why folks don't consider using an infrared focusing system from something like the Hexar AF instead of Lidar. The biggest achilles heel of every AF P&S is missed focus. That's why I generally don't use them. Too many "focused behind somehow" the centered subject photos to count. if the Rollei can't be 95% accurate in real world situations, then it would never be for me.
Same here. I'll keep shooting with my Olympus Stylus P&S. If it fails, I'll consider a Rollei 35 SE.I dunno about this.
Just a slightly larger brick. 🙂Seems a bit like a brick in handling.
Actually, Rollei sold many Rollei 35S and 35T cameras with the lens brand marked as simply "Rollei HFT" ... It was part of a cost cutting deal with Zeiss to not use the Zeiss branding on the lens bezel which they dropped in later years when the Rollei 35 Classic was introduced. ALL the Rollei 35 lenses were supplied by Zeiss (and Schneider) in the day.It seems strange for the lens to be just a "Rollei Lens.". I'd like it to be a Zeiss Sonnar or Zeiss Tessar like the original Rollei 35. So that there could be more of a feeling of continuity with the original ones, some idea of the imaging. I'm sure it's good, perhaps a Cosina; but "Rollei Lens" seems unsatisfying.
One of the review videos showed them side by side, but I can't seem to find the clip. The 35AF body is 3-5mm larger in all three dimensions ... not a lot, but quite noticeable. I see it particularly in the top view ... it just looks a bit fatter than the 35S body.Anyone have a picture with the 35AF side by side with the original Rollei 35? The relative proportions seem about the same but the shot with the camera in hand makes it look like it is quite a bit larger.
Do you mean the lenses were NOT actually 'Made in Singapore'?Actually, Rollei sold many Rollei 35S and 35T cameras with the lens brand marked as simply "Rollei HFT" ... It was part of a cost cutting deal with Zeiss to not use the Zeiss branding on the lens bezel which they dropped in later years when the Rollei 35 Classic was introduced. ALL the Rollei 35 lenses were supplied by Zeiss (and Schneider) in the day.
G
Yes, you have to use both hands to operate the old Rollei 35 (...35S, 35T, etc), because the shutter control and wind lever are on the left, aperture and shutter release on the right. The wind lever does have a long travel. You get used to all this quickly enough.The film wind crank on the new 35AF seems less than ergonomic, it has to be wound >180 degrees … with the left hand! Meanwhile the shutter has to be operated with the right (because of where the button is located), meaning this is a two-hand-operated camera!
Meanwhile some reviewers are saying the original 35 was also like this (I have never used one).
Absolutely not. Rollei 35 production began in Germany in 1966. When the assembly plant in Singapore was opened (about 1970, IIRC), they received assembled lens/shutter/chassis from Germany onto which they assembled the other components and body claddings.Do you mean the lenses were NOT actually 'Made in Singapore'?
The film wind is very very much like the original Rollei 35. And while you might think it "unergonomic" from the context of other cameras that you are familiar with, in use it proves not to be so very difficult as it might seem.The film wind crank on the new 35AF seems less than ergonomic, it has to be wound >180 degrees … with the left hand! Meanwhile the shutter has to be operated with the right (because of where the button is located), meaning this is a two-hand-operated camera!
