Contax IIa mod and service...
Thanks everyone for your replies, this is very helpful.
I think I will dive into the camera and try to loosen up the rangefinder. Maybe it also is just gunk and grime messing up the works.
I'm not sure I want to do anything with the shutter, I'm ok with only 1-1/250, assuming those are relatively accurate after a film test.
If I can't get the RF moving, no loss, I then will decide to send to Oleg. Postage is about $20, insurance about $2 for $200 coverage, considering the camera cost nothing, this is reasonable.
@milescl what kind of leather conditioning did you use? Anything special?
Just some generic Kiwi leather conditioner I had on hand. Doing multiple applications made it so tearing the leather was very unlikely.
Same here at the moment, with my 1936 Contax II. It needs a CLA. I'm looking forward to see the results.
Mine needs a shutter. And I left the lens on it so that is an additional CLA. It can't hurt. My feeling is that I will feel better having a CLA for the lens than if I had not sent it and later wished I had. I will wind up with a very old "shelf queen" which works, takes photos, if I can remember the "Rule of 16's", and sounds like what cameras are supposed to sound like, dammit! LOL I'll run some mono through it and lug it about occasionally for further fun in the field. I really look forward to getting it back. I do not favor film but this baby is special and deserves special attention and care.
And every time I use it will be a thank you to the good person who so kindly sent the darling on to me.
Thank you Miles.
I'm going to tackle the bumps today.
I opened up the IIa yesterday, and like magic the rangefinder started working. Must have been some debris in there or something, took off the top plate, and presto! I didn't actually see what caused it to hang, it was very clean in there, no greasy sludge.
So the camera seems fully operational now, pending a film test, from 1s to 1/250s.
Here’s mine I recently purchased after buying the lens first. I bought the lens not sure what I’d do with it but eventually decided to find a clean working IIa. My first Contax RF. I really like the overall design of the camera from focusing to the film advance knob. It’s in great condition and most shutter speeds sound right to my ears. Now that we have some decent weather I’ll put a roll of Trix 400 through it.
I also have an Amedeo adapter for Contax to Leica LTM but these collapsible lenses don’t work well with it.
I picked up an immaculate Contax IIa with frozen rangefinder and the shutter running at one speed only, wherever the dial was set, for a princely £45 ($50 - odd). Armed with Rick Olsen's basic service instructions, I took off top and front plates and found the rangefinder was fixed just by lubricating the pivot and the shutter (ostensibly, at least) by freeing up and lubricating the escapements.
The residual problem with a camera that now appears to work perfectly is that the shutter won't open reliably at 1/1250th and tapers at 1/500 and (less so) at 1/250. From all I have read on this forum and elsewhere, the problem is due to what you might call differential drag on the shutter curtain bearings, causing the second curtain to catch the first. A deeper dive into the works is required to address this, removing the shutter crate from the body for further careful cleaning and lubrication - and even then there's no guarantee of a fix.
Meanwhile, I bought a Leica IIIG which - as old Leicas tend to do - just worked perfectly out the box. You can see why interest in the lovely, gloriously complicated and beautifully made Contax faded with this kind of competition - and even more so the Leica M3, with its fantastic coaxial rangefinder and multiple frame, parallax-compensated viewfinder that came before the IIIG.
Still, you'll not find a IIIG and certainly not an M3 for Contax IIa/IIIa money today!
I have a II I was gifted. A round trip to Oleg was around $300. I now have a fully functional, working like new Contax II that I am running a roll of XP-2 through. I wanted a CZJ i.5 in Contax mount and found one for $200 with a III attached. And the III is in pretty good shape and the CZJ is coated. So it will go for the round trip to Oleg, also. I really like the old pre-war Contax cameras. They are a good buy when purchased and Oleg can tune them up quite well. All FWIW.
I am nowhere nearly as talented as you to take apart, fix and re-assemble a camera.
Two years ago I got my Contax IIIa, which works well on almost all speeds (except 1/1250s) but viewfinder was hazy. I bought the service manual from learn camera repair, and disassemble far enough to clean up the VF/RF. It is a bit more complicated than IIa without the meter, but doable if you are careful.
These Contax rangefinders are quite enjoyable to use, and the price on both bodies and lenses are lower than comparable Leica LTM.
I was very happy with Oleg's service on my IIa. I got it cheap in relatively unknown condition but complete. Rangefinder needed work, speeds were questionable, the usual stuff. I'm very picky about accurate operation and the speeds are very good, and the rangefinder will focus even the 135 sonnar accurately enough for big enlargements. And it only took a month! Compared to every attempt I've made at having a Leica serviced, this was a dream.
I have serviced/restored a number of prewar Contax IIs and an early 1950s Kiev 2 (which is almost as beautifully made and finished as the Zeiss original). They are not easy and occasionally nightmarish to work on - but those I have succeeded with have proved reliable and delivered some fine images. The IIa and IIIa have a completely redesigned shutter that is, paradoxically simpler and far easier to service but more difficult to get running reliably - at least for amateurs like my own self.
Check with Mark Hansen for repair. I know he works on the IIa
For what it's worth, I tried several times in Jan/Feb to contact him and was unable to reach him. He's done great work for me in the past as well as given very helpful advice and suggestions, so I hope everything is ok or at least improving for him.
Ross Yerkes in California did an original CLA on my Contax iia, then when I needed it he replaced the shutter with an unused one (hard to say "new" in this case). I suspect the shutter failure was my fault, not his. I played with tensioning it. I do not think he has any more unused shutters, but he does seem to keep mine in good working order. He is also keeping my Retina IIIc going.
I inherited a Contax lla with an f:2 Sonnar from my Dad. It has great sentimental value. It was my first camera when I was young. When I inherited it the camera had been sitting for a while and the shutter had stopped working.
I wanted to get it up and running. I hate to be discouraging but I had a nightmare getting it serviced.
I put myself on Henry Scherer’s list twice, and somehow got bounced off twice. I decided to move on to Plan B and sent the camera to Mark Hanson. It came back after 6 months, which was ok, with a light leak, which wasn’t OK. I spent the next 6 months chasing Mark who had the nerve to complain to me he has to pay money for film and processing to test the camera and put paying jobs aside to do my warranty work.
It’s a beautifully made camera and the optics are amazing. But few people work on them, fewer still do a good job. A couple months back, after using the camera for maybe 5 years, my rangefinder stopped working. Rather than go through any of that again I bought an M3 and an Amadeo adapter for my Sonnar in spite of the sentimental value.
If it is only that the rangefinder suddenly stopped working after previously working normally, I'd be happy to have a look for you if you would entrust me with the camera. Is there anything rattling around that wasn't before?
If it's inappropriate to piggyback on this thread, please let me know.
I have a Contax IIIa that is non-functioning. The shutter is locked up, and the rangefinder is cloudy, but (if memory serves) I think tracks the full range. Meter does not appear to work. 50mm collapsible lens. The camera was my father-in-law's, and is in very nice cosmetic shape. When I did my research several months ago, there was a "Contax guy" who has a very extensive website, but who apparently is not accepting work. I checked out Oleg's site, and while he does appear to be accepting cameras, it looks like the bill could crowd $500 US including return shipping, IF there is no tariff surprise on return. I'll reach out to him to see if my estimate is close.
But my question to members in the US is whether there is anyone in the States who can be reliably used to CLA/repair a IIIa. I can't prove that Ross Yerkes is accepting rangefinders; he may be the person who is now only working on Rolleiflexes. (My attention to this task has been intermittent...)
Thanks for any and all assistance.
Oleg is the best option in 2025.
After shipping it should be closer to $300, unless you’re paying for speedy shipping and additional insurance.
Thread viewers
