iskra
supermax
9:37 AM
Have you ever took photos with a iskra?
What do you think about its lens quality?
I would like to buy a not heavy MF camera and I read on the internet that it is very good
It's a great lens on a pretty good camera. It is larger and heavier than you might expect. Mine weighs about 1 kg (about 2.2 lbs), almost as much as my Rolleiflex 3.5E.
Do you think there is a better folding Mf RF or another light MF camera?
I have Lubitel but lenses don't sutisfy me
I need a very good quality lens
If you can find an Agfa Isolette or Zeiss Ikon you will get a simple 6x6 folding cameras. Some problems, holes in the bellows and sticky shutters. I have an Isoleette I love, light and pocketiable. Upscale, I have a Fuji GS645 Professional that has been serviced and a new English leather bellows added and it is exceptional, but it is expensive.
Zeiss Ikon with a Tessar or Agfa Isolette with a Solinar are best. If you are willing to stop down to f/8, then a 3-element Novar or Apotar will work just as well and cost much less. The Zeiss cameras have much better build quality than all but the later Agfas. The bellows and focusing grease on most Agfas will need replacing. I prefer the simpler Zeiss and Agfa folders to the Iskra.
There are some threads about the Iskra in RFF. Look here
and here
I love mine (some photos in my gallery). I bought it from Alex-photo (ebai) and works well as described, but is not perfect (stiff focusing) If you are looking for info about MF folders or want to buy a perfect working MF folder, take a look at www.certo6.com (he sells in ebay too).
I read on the internet that lenses of Iskra (and Tessar I suppose after your responses) are better than Kiev 88 and Kiev 60 lenses: do you agree?
Yes it is heavy and tad bulky, but for the money the Iskra is probably the best of the old folders, that is if it has been serviced by Oleg at http://www.okvintagecamera.com/
Agfas built between 1949 and 1955 usually need their bellows replaced. I've been playing with a Voigtlander Perkeo II for the past couple of months - It is by far the smallest 6x6 folder.
I have two folders from Certo6, I would highly recommend getting a folder from him! I have also had an Iskra, but as said above, it was much more heavy than I was expecting!
jano said:
Iskra is great, especially if you don't care about overlapping framelines. The lens makes an interesting swirly background at the wide apertures 🙂
I'll have to try it wide open. 🙁 Seems ok when stopped down a bit. 😀
Isn't overlapping frames a common problem with all the old roll film mechanical advance systems? My RB67 backs sometime get confused. :bang:
Regards. :angel:​
Iskra 2, no idea about the overlapping frames. I just know it appears to be a problem with most of the iskra cameras out there (I researched the heck out of it, and certo6 took a look at mine to see if he could fix it, no luck, needed a full new system inside as the gears were all worn). The swirly background thingy is kinda neat.. look at the background in the green, it's hard to tell on the small picture, but when you get to about 33% zoomed in on the full res scan, or print 10x10, it's fairly obvious:
http://www.rangefinderforum.com/photopost/showphoto.php?photo=46011&ppuser=2711
By the way, amazing color on your photo!
Many Iskras have been heavily used so it is not surprising the film advance mechanisms are worn on some. I have three Iskra 2's and the film advance works on all of them. Tessars are not noted for their 'bokeh', and your shot demonstrates that characteristic. I'm going to try some closeups wide open with one of mine. I have an old Schneider 210 Xenar which has an evil 'bokeh' when used wide open on a close subject.
Thanks for the compliment on the pix. Astia 100 captured the "Kodak Moment". Regards.
I'm coming in late, but I'll do this answer without reading the other responses intentionally.
To me, the Iskra was the finest camera made in the FSU. Period. The lens is simply the finest they ever fit to any camera. There is an internet rumor that they used the last of the glass confiscated from CZJ at the end of the war to make the Industars in the Iskra. I don't know if it's true or not, but the lens is so much better than anything else I've seen from the FSU that I find it very easy to believe.
It remains the single finest of the "folders" made in the east or west. A good example is worth far more, I believe, than they are currently commanding. One of my favorite examples from the one I used to own (alas...) is here: http://www.rangefinderforum.com/photopost/showphoto.php?photo=13322
What more can I say? Diamonds & rust...
William
Evil bokeh? hahahahahaha 😀
I kinda wish my I2 wouldn't have overlapping frames.. the thing looks almost new on the outside, the meter still works, and the inside is a little worn out, but very clean. I have a hard enough time cutting the damn 120 neg straight to fit in the sleeves, let alone figuring out where one frame ends and where one begins. *grumble*
Before my richo kr10m (SLR) i used a fed3 with industar 61 55/2.8 which was not perfect at the maximum diphragm. Much better was the lenses of Zorki 10 at any diaphragm.
Do Tessar,solinar and 58 work well at any diaphragm?
