Dougg
Seasoned Member
Thanks, Shadowfox... At first I didn't have a lens wider than the 40mm that came on my first FT, so I used the M42 adapter with a 28mm f/3.5 SMC Takumar, using the lens auto/manual switch to stop down for each exposure. A bit inconvenient and I forgot a few times resulting in overexposure. 🙂 I've also used the Pentax 50mm f/1.4 as a fast short "tele." This adapter really opens up another huge range of lenses for the Pen.shadowfox said:Nice setup you got there, do you pair any Takumar lenses with the Pen? how do you like it?
PS: If you are ever thinking of letting go of your FV, do give me a shout, ok? 😉
Since then I found both the 25mm f/2.8 (rarer than the f/4 version) and the 20mm f/3.5. the latter is a lovely sharp little lens that's become a favorite (about 30mm equivalent field of view).
The FV came from KEH and then got a needed CLA so I've got $$$ into it, but maybe I don't "need" three F bodies... If you're interested in discussing a purchase, send me a PM.
Photo of the FV below and a couple shots from it using the 20mm lens...
