Handmade camera for next to nothing
trittium
4:17 PM
Central CT
I bought a bought a dirty old oak box at salvation army and transformed it into a beautiful homemade pinhole camera. It look a lot of old english scratch cover wood polish to get it looking good, but Here it is. The box cost 75 cents
I made a hole in the top with an exato knife and glued a brass washer over it. I cut weather stipping ($1.98 for a 12 ft roll) and cut it on an agle to make it light tight.
Then I cut out the bottom of the box to allow light to pass through. The whole thing is held together using tension from rubber bands. A 4x5 back can be held on as well as a 6x9 rollfilm back.
Finally I tapes a piece of light light tight plastic on the inside of the camera with a tiny pinhole in it.
This just goes to show you that with a little thinking and a little work, you too can make a beautiful easy camera. I will post some image taken with this later. I need to work out exposure times for the camera.
Thanks everyone! To answer Eriks question, the ground glass is actually 9x12(old plate film size) in a 4x5 adapter. I have a 9x12 plate film to film 6x9 roll film adapter I am planing to use with that. I am trying exposures with 4x5 right now. I am hoping to develope them tonight.
I am having some issues. The original pinhole was way too small. The washer was also blockinging off some of the pinhole. I solved this by mounting the pinhole on the front washer. I am also having issues working out exposure time with 4x5. It takes so bloody long. I have to get my roll film back, back. It is currently attached to my voigtlander alpin that is at the repair shop. 🙁
With pinhole photography, shutter times can run into minutes, even hours. It's definitely not a technique for the impatient. 🙂
RML is right - reciprocity failure can push your exposure into hours - there is a nice pinhole designer / exposure calculator at www.pinhole.cz by David Balihar - made things a lot easier for me 😉
Finally got some decient results. I shot 10 years expired kodak ektachrome 64t and developed in in Diafine.
8 min exposure
5 min exposure
6 min exposure
5 hour exposure of me sleeping
Looks good. I really like it!
Maybe I'll look into a pinhole for rollfilm, use a small red window to count frames, same method as yours - using an old wooden box.
nice cam, and nice images, but are the circular framing issues due to the size of the brass 'O' ?
I don't think so, with a bright light the image extends to the corners, I just think that the hole isn't far enough from the back of the film. I think they are off center because the brass "o" isn't mounted perfectly.
The exposure times don't look to bad for indoors! Foamcore works wonders for pinholes, too.
30 seconds on a bright, sunny day.
5 minutes in the shade; could have used a tad more.
