sirius
Hi Joe, did you take your OM with the 28mm lens out for some street shooting? How would you compare that to working with the Ikon?
Ah, I guess we mean the same thing. Of course, if your optical system is misaligned, any visual feedback you get with a SLR is rather worthless, but that's not what I meant. If we want to compare cameras, of course we have to assume that the optical system is in alignment, since neither rangefinders nor SLRs will give particularly convincing results if it isn't 🙂Pherdinand said:But no, you don't get immediate feedback. It's exactly what I tried to say above.
When you focus (manually or AF) a SLR, you focus an image on a ground glass in the viewfinder (with AF sensors or with focus aids). This image has to be properly aligned to the same distance as the film plane when the mirror is up, otherwise you focus , you are happy with the result you see in the viewfinder, and the image will be out of focus. [...]
Pherdinand said:Here's an experience i had and amazed me:
Take an el-cheapo minolta x-370 manual slr camera. Put a fifty mm lens on it 50/1.7 is always very cheap.
The whole kit can cost you maybe 40 or 50$ nowadays.
Lift it up to your eye. Look through the "tunnel" viewfinder.
You will see a huge image with 1:1 magnification competing with the brightness of my leica M2. No, seriously.
Until i can afford a DSLR with such a viewfinder, i am not very interested in dslr's.
EDIT: Philipp, that's indeed what I mean as well🙂
FrankS said:It must have something to do with the process, because the end result - the pictures, are just as acheivable with an slr. (Yes, RFs are better in low light, but slrs are better at other things like macro and tele.)
jlw said:For me, it's very much the "vision thing." RF cameras and SLR cameras have a literal, concretely technical difference in the way you see: you look into an SLR and see an image, while you look through an RF camera and see what's in front of you.
I'd say the SLR isn't more of a "liar" than the rangefinder in this respect. I would concede that with some SLR models you have a few extra percent of picture on the final frame because the finder only shows 96% or so, but then we're comparing with rangefinders that are optimised to show 85% or so of the frame at three meters, and with lenses whose physical focal lengths can be off by another several percent from the value for which the framelines are calculated. In this respect the rangefinder is the bigger liar, if we want to call it lying. SLR viewfinders are almost always more accurate.shg005 said:=in SLR you can see an image= - incorrect!!!, SLR is a big liar, image within film frame or on sensor will be another.
RF is not lia to you, beacause you and only you have to make a decision =What image in what moment I want=
When I did say =liar= I said not about 85% or 95%. I'd say about structure of image.rxmd said:I'd say the SLR isn't more of a "liar" than the rangefinder in this respect.
Philipp
