Collapsible Tessar 50/3.5 (1931) on Contax IIa
Joerg
Dilettant
10:27 AM
Newton, MA
so I scored that collapsible 50/3.5 Tessar lens from 1931 recently.
Proudly put it on my Contax IIa........and the pics are beyond blurry.
Just wayyyyyy out of focus. So much that you might recognize a light sources as a lighter spot on the negative😕
Is the old lens from the Contax I days incompatible with the IIA?
Am I doing something wrong with the extending part?
Is the lens faulty?
Any input is appreciated....
Ciao
joerg
It is not obvious, you need to remove the lens from camera and pull it out like it is a telescops and then rotate so the little wedges lock in place.
The lens will have real good performance...
If the little lugs dont lock resonably tightly then you will need to repost and some one will tell you how to address yourself, it is not obvious, or it is send away time.
Noel
Yes I extended the lens.....
but maybe nor enough, too far.
i actually got it locked with the little wedges, but.....I have to recheck again....
Thanks
joerg
The lens being from 1931, I wonder if there is a compatibility issue with a post war Contax IIa?
Bob
Hello, if that's your first collapsible, maybe try extending/locking it before snapping it in the bayonet mount so you get used to how it should normally lock ?
When I lock my 50/2 collapsible Sonnar, with the camera and lens facing me, I turn the lens clockwise and it locks at 45° angle.
Max
Thanks for all the help.
Serial # indicates, and appearance as well, a 1931 lens.
i will try the extension. Anyway to test the focus without a film?
Ciao
joerg
Joerg
3m matt tape across the film inner rails and loupe, set the shutter on T, focus target for close up, star or street lights in distance for infinity.
Noel
