RD-1 80-90mm lens question
espressogeek
9:35 PM
Nashville, TN
I have the 90mm Elmarit-c . I'm still not to sure on the performance of this thing. I need to spend some more time with it. I would like to have a lens a stop or two faster for those moments when nothing else will do. Has anyone shot a significant number of the canon 85/2 or 85/1.9 lenses on this camera? I'm on the hunt for a konica 90/2.8 but just in case i want to consider the canons.
Due to the short baselength of the rangefinder those lenses will be hard to focus at wider apertures than f/4 without the 1.3x magnifier.
With the latter, f/2.8 should be OK but hardly wider AFAIK.
Never tried the magnifier myself though.
I would be willing to give a magnifier a whirl if i can focus reliably at 2.8 . I typically wouldn't be using it up close to something to hopefully a little slop could be tolerated.
I have a 100mm f/2 Canon that I use on my R-D 1 for lecture-podium shots and the like (see attached example.) My success rate is pretty good at distances of about 10 meters and up; at closer distances, it gets riskier the closer you go, although I'll almost always try it if there's a chance of getting a good shot.
As others have said, the R-D 1's short RF base makes it very challenging to get good focusing accuracy with longer focal lengths at wide apertures -- but an eyepiece magnifier helps, and so does using the split-image focusing technique. (To do this, you find a hard vertical line in the subject and focus by lining up the split in the line at the edge of the rangefinder patch; the eye does this more accurately than it aligns two coincident images as in normal rangefinder focusing.)
In the example picture (of a guest lecturer on Impressionism) I used the split-image technique to focus on the frame of his eyeglasses. I was shooting with the 100mm lens at f/2 at a range of about 12 meters, and in the second image (a pixel-for-pixel crop from the first one) you can see that even at this long distance DOF was pretty limited -- the far side of his face is a bit softer than the near side. Still, most of my pictures of the lecture were pretty well-focused. Of course, it's harder if you're dealing with a more mobile subject!
Well I snagged the canon 85/2. I wil see how it does around 2.8. I am shocked at how much the hexanons have went up! I seem to remember them around the three to four hundred dollar mark and now they are 600 +! I might spring for one anyway but I want to see how the canon does first.
The Canon 2/85 should work fine. I've done a few aimless shots with an old Serernar 2/85 with the R-D1s and the focusing is on the dot, even at f/2. Just couldn't use it seriously, due to the lack of a decent 135 VF to view for it.
Jay
I shoot alot of theater photography on my R-D1 with a 90mm F2 Leica lens. Works great wide open, which is just about the only way I use it. I can even hand-hold it down to 1/15th of a second on my R-d1 if I attach the CamerQuest rubber handle to the lens tripod thread. Here is an example:
T.
mountainrivera said:
I had a 90mm 2.0 asph but had to sell it. Really did not focus wider than 4.0 with any consistancy. Try one before you buy if you can.
It's in good use now, though, Mike 🙂
Back to topic: on the Bessa R2 I was able to consistently focus 90/2.8, also close-up. 85-90/2 always gave me problems up to a few meters distance.
I played with Robert's RD1 last week, using my 85/2 Nikkor, and it was impossible to focus wide open, close up.
Roland.
Well, take it from someone that has wrestled with close focusing the R-D1, with 3 or 4 top off adjustments to my credit. You have got to get acceptable close focusing on the R-D1, before you can attempt an effective focus technique with a 90mm.
The current 90mm Elmarit is a benchmark lens that can be found for reasonable prices and mine is a pleasure to focus and focuses consistantly at all distances, now.
Judge of framing is required, however.
The 135mm is another story...
You guys are right the focus of an 85/2 on this thing is all over the place. I think this shot was around f2.8 and i missed it. But I actually like the way it turned out.
