Repair manual for Leica IIIG
leicam
8:33 AM
Outside Oslo, Norway
I have just got a Leica IIIG. I try to load i film in it, but it would not enter properly. Then it fall out some pieces of old film from the body. I seems like it is still some more in there.
Anybody who knows how to open the body so I can remove the rest of these pieces.
When I take the end of a film between the back and the shutter, I can move these pieces around, but I am not able to take them out without taking the body apart.
:bang:
I guess the IIIg is similar to the IIf in that way. You can unscrew the small screws in the front and take the bodyshell off. Gently push the pressure plate when you do take the shell off to avoid scratching it. Beware not to lose the two springs behind the pressure plate.
Welcome, by the way!
First buy a big air bulb blower, hold the camera baseplate down and blow and to try and dislodge film bits, then try moving with scrap film, tweasers, any thing...
Try removing the lens then firing the shutter on T and removing any bits of film through the shutter aperature but out via the baseplate, flash light, dental mirror, and probably necessary tools for this.
If you got lots of bits film in the shutter blind area that is more difficult. Watch makers screw drivers, small pliers, eraser rubber etc.,... and
http://rick_oleson.tripod.com/index-154.html
http://www.mediajoy.com/en/lrc/lbal/index2.html
http://jay.fedka.com/
Be careful.
Noel
Hi everybody and good morning. It is 07:30 AM here in Norway now.
Thank you very much for your great help all of you.
I downloaded the repair manual for the IIIf from www.pentax-manuals.com (thanks John). The bodyshell and self-timer at the IIIf and the IIIg are indetical. I found some more film chips inside.
Now it is tested and everything works fine again, except I did not manage to adjust the self-timer at first attempt. Printing out the repair manual, then I fix that part later.
